2nd Aircon pump for 80 series Cruiser
Submitted: Monday, Oct 13, 2003 at 22:06
ThreadID: 7801 Views:1973 Replies:4 FollowUps:4
Hi I am Louis Reichert from Namibia Southern Africa and I am new to the list. I want to fit a 2nd aircon pump to my 80 series 4.5 petrol for pumping tyres I am looking for details where to fit it and how to make the mountings and from wich pulley does it work the best. If anybody got diagrams or photos please e-mail me at expserv@iafrica.com.na
Reply By: Coops (Pilbara) - Monday, Oct 13, 2003 at 23:43
Louis,
Brackets will be the biggest hurdle that you will have to overcomeAllyn
Where to next ?
AnswerID: 33685
Follow Up By: Sandtracks - Tuesday, Oct 14, 2003 at 00:03
I thought so to i had one on my Mazda B series double cab which I want to install in my LC 80 series now
FollowupID: 24198
Reply By: Member - Bradley- Tuesday, Oct 14, 2003 at 11:03
Hi louis, check out the ENDLESS air compressors, they are modified air con pumps and should have a complete kit for your 80 series IE- brackets etc.. Not sure of their web address but a search of aussie sites should find them easily. BradLife is short- but there's always time for a yarda.
AnswerID: 33717
Follow Up By: Sandtracks - Tuesday, Oct 14, 2003 at 18:29
Thanks I will check if I can find them.
FollowupID: 24251
Reply By: Member - DOZER- Tuesday, Oct 14, 2003 at 12:44
Gday check out this URL
I have one fitted to my petrol cruiser, worth every second of fooling around. Got the pump from a Mitsubishi at the dismantler for $50, and a industrial pressure switch for another $50
http://www4.tpgi.com.au/users/kellyf/wheredayathinkwer mike?
AnswerID: 33726
Follow Up By: Sandtracks - Tuesday, Oct 14, 2003 at 18:33
Thanks this helped a lot I have the same pump that is shown on the site so I must just get the brackets made up and fit it.
FollowupID: 24253
Follow Up By: Member - DOZER- Wednesday, Oct 15, 2003 at 12:17
The only difference is the grease nipple in the plug half way down the side of the pump. I drilled and tapped a hole to suit one and filled it up with 50 pumps of Synthetic grease which turned out to be too much because it came back out of the discharge line, clogging the water trap i had in the line.I run a reservoir to operate lockers, but you may not need to run this and can have a hose straight off the pump if you so require (more chance of human error this way) but be careful if you do.
FollowupID: 24341
Reply By: Sandtracks - Wednesday, Oct 15, 2003 at 14:48
I checked my pump is actually the SD507. Can I just replace the plug with a grease nipple and how much grease do you thinkwould be sufficient that would not push out at the discharge line do you think 10 pumps would be sufficient. I have heard of people filling it once a year with Prolong or similar product in stead of grease what do you think if this.
AnswerID: 33899
