AnswerID: 2196 Submitted: Tuesday, Feb 26, 2002 at 00:00
Stuart - All Terrain 4WD Adventures
replied:
Michelle,
If you are going to be doing any long term travel around OZ then I would consider a
suspension upgrade for the following reasons: 1.your loaded vehicle will probably sag in the rear on standard
suspension reducing ground clearance and handling. 2.the standard shocks and springs would probably fade driving on corrugated roads. 3. even easy 4wd tracks can have washaways/ruts requiring that extra lift an aftermarket
suspension kit can provide. 4. spending $1200-1400 on this modification to your vehicle will also cater for the extra weight of
accessories like bull bars, dual batteries, roof rack + gear,
winches, people, fuel, water etc.
Whilst your car may appear suitable in standard trim unloaded it will probably be a different beast when loaded. Why not try loading it up with all your gear and then see how it looks. The other side of the coin is how long are you going to be traveling for and is it worth the expense.
Stuart
Reply 3 of 5
