95 Landcruiser Auto acting strange
Submitted: Thursday, Oct 16, 2003 at 22:35
ThreadID: 7876 Views:1694 Replies:2 FollowUps:2
Hello PPL, I have a 95 80 series Landcruiser. It runs on LPG and has an auto. It seems to slip into first gear then engages into second gear with a thud. It does this randomly. Also the other gear changing seems very erratic. My question is, can the erratic gear changing be fixed by reprogramming the transmission controller?
Reply By: tour boy - Friday, Oct 17, 2003 at 06:49
Have you had it serviced recently as sometimes they over fill the oil.
AnswerID: 34110
Follow Up By: Matho - Sunday, Oct 19, 2003 at 18:07
Yes it has been serviced but I checked out the the oil level and it fine.
FollowupID: 24746
Reply By: Tony - Friday, Oct 17, 2003 at 07:44
The codes can be wiped, but most times its a computer fault that causes the gear changes to behave the way you explain.
Try and find a transmission workshop that has a machine and plugs to suit the L/C, sometimes a service on the tranny will solve the problem, but more than likely it will be a software problem. (ever been through deep water)
AnswerID: 34112
Follow Up By: Matho - Sunday, Oct 19, 2003 at 18:12
Your proberly right. Tranny CPU might have some faults, so i'll have someone take look at it. (Nope I've never been though water but the ex-owner might of. :-D) I'll keep you posted with my result.
FollowupID: 24748
