Gq Patrol RB30 Secondaries
Submitted: Sunday, Oct 19, 2003 at 03:44
wilkie
Hi in a previous post some one surgested to me i check to see if the secondaries in my carby were working does any one know how this is done pls
Reply By: kezza - Sunday, Oct 19, 2003 at 13:49
Wilkie
Quickest way would be to lift your air cleaner off look in and watch the lower butterfly valves and rev it up till both open the primary will open 1st and as the revs increase - over 3000 rpm or so the secondary will open
34346
Follow Up By: wilkie - Monday, Oct 20, 2003 at 19:42
thanks Kezza did as you surgested but the secondard butterflys did not open when i push the butifly down with a peace of wire i can see the fuel poor in
any surgestions Wilkie
24848
Follow Up By: kezza - Monday, Oct 20, 2003 at 21:01
When checking make sure you open the throttle fully for an instant as the second throat may be opening at higher revs I think there is a mechanical as
well as a vacuum trigger for the second barrell.
If it opens too soon - too thirsty
If not working at all it may have been disabled and youd get about 13 lit\100 km most of the time.
If in doubt and 2nd barrell not working at all
Overhaul the carbie - probably due.
How many Ks? How is it running? How much fuel does it use??
Need to look at this closely before pulling it apart.
kes
24876
