patrol 1994
Submitted: Sunday, Oct 19, 2003 at 14:57
ThreadID: 7924 Views:1570 Replies:3 FollowUps:1
hi there, first time user here.
i have a 1994patrol on petrol and yes its thirsty but that was to be expected. i am hoping someone may have a suggestion as the few mechanics did not know or could not be bothered. i think its a transmission problem, its an auto. it goes well when first driving around for half hour or so then if i stop and turn the car off for 10 minutes and then get back in and get going the problem starts. firsly it will rev out higher in first then really jump into second and really rev hard like i have selected second gear only. if i catch the red light i get worried as it gets very jumpy at idle reving up to 12/1300 then down then up and the bloke beside me thinks i want to drag him. i get going and under accelaration the car chugs along. its like there is no go and the tacho just drops and then all of a sudden it gets power again then drops then goes then drops and so on and this happens on freeways doing 100ks also and i have to slow down to about 50ks which is a bit scary. it chugs along for a few minutes and then its running good as gold again but i dare not stop and turn the car of for a while or it happens all again. if any one has heard of this happening please post me as i would really appreciate it so i could get it fixed as apart from that the car is great.
thank you all
Rod from Melbourne
Reply By: diamond(bendigo) - Sunday, Oct 19, 2003 at 15:05
gday rod.
sounds to me like a fuel problem.
have you had the car serviced since you have had it.
try changing fuel filter to start with/air filter.
fuel pump and maybe carby could be playing up to but start with the easyest first.
back bye popular
demand lolol
AnswerID: 34349
Reply By: Truckster (Vic) - Sunday, Oct 19, 2003 at 21:52
Air leak of some form, no vacuum,
Did you have a prepurchase inspection done?
Have it serviced first. then see where you stand.
AnswerID: 34399
Follow Up By: rod - Monday, Oct 20, 2003 at 08:58
gday truckster,
yeah i had the inspection and yes i have had it serviced but when i talk to the mechanics they say they have to see it and thats the tricky part.
thanks though but i will check out the vacuum.
thanks rod
FollowupID: 24790
Reply By: Eric Experience. - Sunday, Oct 19, 2003 at 23:10
Rod.
The most likely cause is the cable that runs from the carby to the auto, if that cable has been under water or damaged they get sticky. remove it from the carby end pull it to determin if it moves freely. Eric.
AnswerID: 34408
