IPHONE 3G GPS
Submitted: Sunday, Jun 13, 2010 at 20:52
ThreadID: 79314 Views:7846 Replies:8 FollowUps:24
I am a bit confused about the GPS capabilities of the iphone 3G.
All the blurb you read talks about GPS but I think it is limited to GPS via the phone network not via satellites.
In other words it does not function like my PDA which connects to a GPS via bluetooth - or can it.
Any clarification on this would be appreciated.
Richard
Reply By: Member - Doug T (NT) - Sunday, Jun 13, 2010 at 22:16
My opinion is if you want a phone then buy a phone, if you want a GPS then get a GPS,
AnswerID: 420696
Follow Up By: olcoolone - Sunday, Jun 13, 2010 at 22:24
We use the Iphone for a handheld GPS now, can do a lot more then the stand alone old fashioned ones you by from the main stream GPS manufactures.
FollowupID: 690869
Follow Up By: Glenndini - Sunday, Jun 13, 2010 at 22:29
Because a phone could not possibly surf the internet, show videos, play music, take photos, record video, play games, work as a calculator, etc, etc, etc, etc.........and do GPS as well.........................oh wait.........yes they can.
FollowupID: 690870
Follow Up By: Member - Doug T (NT) - Sunday, Jun 13, 2010 at 22:44
Glenndini
When I surf the net I use a PC, when I watch video's I use the BIG screen TV/Monitor, I take video's with a HD video camera and the quality is far better than phones, I play MP3 music LOUD on my PC or car radio, when I take photo's I use a $1000 camera,the size and quality is far better, can't be bothered with stupid games, for a calculator I can use the GPS, PC or a calculator, also the GPS plays music, Unit converter, world clock, picture viewer, My phone does not send or recieve text, does not send or recieve video, does not have message bank, cannot call overseas or 1900 numbers, it's all been closed by my request, all I want is a phone,
FollowupID: 690873
Follow Up By: olcoolone - Sunday, Jun 13, 2010 at 22:51
Sooooo what do you watch Youtube on?
FollowupID: 690877
Follow Up By: Member - Doug T (NT) - Sunday, Jun 13, 2010 at 22:56
olcoolone
On my HD TV / Monitor 590mm X 350mm screen , You Tube full screen .
FollowupID: 690879
Follow Up By: Glenndini - Sunday, Jun 13, 2010 at 23:28
You are without doubt the world arbiter on everything technical and I bow to your unquestioned superiority on such matters.
FollowupID: 690882
Follow Up By: Member - Doug T (NT) - Sunday, Jun 13, 2010 at 23:40
Glenndini
Thanks but I do make stuff ups at times, like now after having been into the Adelaide River Rodeo tonight then I come home and spell the word Receive wrong in my upper post. It's a wonder you didn't spot it.
FollowupID: 690883
Reply By: olcoolone - Sunday, Jun 13, 2010 at 22:21
The Iphone GPS is the real deal, they use AGPS...the A stands for assisted whereby most GPS's are just GPS.
AGPS system by itself is a GPS with a full-blown gps chipset, SIRF3 or Globallocate chipset. the "A" is a additional or complimentary function, rather than a enabling function. i.e. w/o the "A", the system can still run.
What the "A" is about is basically a technology whereby the satellite orbital path can be projected over a period of 2-10 days, depending on the technology. GPS with a "A" will be able to have access to such projected path in advance, instead of getting it during each cold fix, which will only be valid for 4 hours anyway.
the TTFF (time to first fix) is a lot quicker with AGPS.
AnswerID: 420697
Reply By: mikehzz - Sunday, Jun 13, 2010 at 22:39
It works out in the centre where there is no phone signal, it just takes longer to get a fix. To be honest I like the iPhone but the weakest part of it is it's aerial, phone or gps. The maps application which comes with it relies on google which does require a phone data connection. To get a proper gps program with maps on the phone means buying Sygic or Tom Tom for street maps, or something like Memory Map for topo maps. There are others but they require a lot of fiddling and converting to get going. I have all of the above and still use a 7" win ce Chinese gps with oziexplorer instead if that's any indication.
Mike
AnswerID: 420701
Follow Up By: olcoolone - Sunday, Jun 13, 2010 at 22:48
Mike I think you getting confused a bit, Google maps need internet connection to work, the phone logs on the internet and the GPS inside the phone tells Google where you are.
The phone only acts as a gateway to the internet.
You can run software that enables you to use Ozi Explorer map files on it or if you have internet connection you can download a snapshot of a Google map to use later even if you out side phone range.
The Iphone works the same as any handheld GPS and doesn't need phone coverage.
The old 3G phones with no GPS could use Google maps but it was used by triangulation of your signal to give a rough location.
FollowupID: 690875
Follow Up By: olcoolone - Sunday, Jun 13, 2010 at 22:50
Sorry Mike miss read your reply!
I've just said what you said...sorry
FollowupID: 690876
Follow Up By: mikehzz - Monday, Jun 14, 2010 at 07:20
No worries. My iPhone took about 15 minutes to get a fix out near Mt Dare and then the sat signal kept dropping all the time. Definitely no phone reception as I am with Vodafone which is a total dog out there. Maybe atmospheric conditions but my other gps didn't seem to be having a problem. I was having fun comparing them.
To reanswer the original post.....yes it is a gps but you need maps for it to be useful. In it's basic form it uses the phone data connection to download maps for the area that the gps says you are in, so no phone signal, no maps. This is where most people get confused as there can be 2 connections, the gps to a satellite and the phone to a phone tower. To add to the confusion the phone is 'helping' the gps when it can by triangulating it's position from the phone towers.
In short if you buy maps for the phone then you do not need mobile reception for it to be a handy little gps.
Mike
FollowupID: 690902
Follow Up By: Member - Graham H (QLD) - Monday, Jun 14, 2010 at 09:39
My understanding of A GPS is that it uses the celullar towers to get a location fix.
Some phones have only that and dont work away from towers.
I have of course been wrong before so.....................................................
FollowupID: 690919
Follow Up By: olcoolone - Monday, Jun 14, 2010 at 10:21
Mike we get good satellite reception with our two Iphones, even indoors...If it's under warranty I would get it checked.
Graham the AGPS is a true GPS, it doesn't rely on phone coverage.
The benefits of AGPS are:
Better acquisition time.
Better for low signal areas or indoors.
Less power consumption.
The Iphone is still behind our Qstarz BT-Q818X GPS mouse...the Qstarz is a AGPS reciever to.
http://www.qstarz.com/Products/GPS%20Products/BT-Q818X-F.htm
FollowupID: 690926
Follow Up By: Member - Graham H (QLD) - Monday, Jun 14, 2010 at 10:40
http://en.wikipedia.org/wiki/Assisted_GPS
As here is what I meant
A typical A-GPS-enabled receiver will use a data connection (Internet or other) to contact the assistance server for A-GPS information. Some A-GPS devices cannot fall back to standard GPS, needing cell tower or internet signal as these A-GPS devices won't function with only GPS satellite signal.
List of devices with Assisted GPS:
Apple iPad[1]
Apple iPhone 3G[2]
BlackBerry Bold [3]
BlackBerry Storm 9530 [4]
E-TEN Glofiish X500
E-TEN Glofiish M700
ESCORT Entourage CIS [5]
ESCORT Entourage PS [6]
Hewlett Packard IPAQ 614c
Hewlett Packard IPAQ 914 - Release expected June 8
HTC Advantage X7500 (HTC Athena 100)
HTC Advantage X7501 (HTC Athena)
HTC Advantage X7510[7]
HTC Artemis 100[8] (HTC P3300)
HTC Census (HTC P6000)
HTC Dream (with Google Android software release 1.5)[9]
HTC Hero
HTC Magic
HTC Omni
HTC P3600i
HTC Pharos 100[10] (HTC P3470)
HTC Sedna 100 (HTC P6550)
HTC Sirius 100[11] (HTC P6500)
HTC Titan 100[12] (HTC P4000, Sprint Mogul _Permanent_Painted_Coatings.aspx-6800, Verizon Wireless XV6800)
HTC Touch Cruise[13] (HTC P3650, HTC Polaris 100)
HTC Touch Diamond[14] (HTC Diamond, HTC P3700)
HTC Touch Find (HTC Polaris 200)
HTC Touch HD (HTC Blackstone)
HTC Touch Pro[15] (HTC Raphael 100)
HTC Trinity 100 (HTC P3600)
HTC TyTN II[16] (AT&T Tilt, HTC Kaiser 120, HTC P4550)
Land Rover S1
LG KC910
LG KM900 Arena
Lg Incite
Lg GT505 Pathfinder
Motorola A3100
Motorola A1600
Motorola A1000
Motorola A925
Motorola A835
Neo 1973
Neo FreeRunner
Nexus One
Nikon Coolpix P6000 Compact Digital Camera[17]
Nokia 5230
Nokia 5800 Xpress Music
Nokia 6110 Navigator
Nokia 6210 Navigator
Nokia 6220 Classic
Nokia 6650 fold
Nokia 6700 Classic
Nokia 6710 Navigator
Nokia E52
Nokia E55
Nokia E66 (Nokia Dora)
Nokia E71
Nokia E72
Nokia E75
Nokia E90 Communicator
Nokia N78
Nokia N79
Nokia N82
Nokia N85
Nokia N95
Nokia N95-3 North America
Nokia N95 8GB
Nokia N95 8GB North America
Nokia N96
Nokia N97
Nokia N810 (with Diablo firmware upgrade)
Nokia N900
Novatel X720
Novatel MiFi 2200
Novatel MiFi 23xx series
Palm Pre
Palm Treo 800w
Palm Treo Pro
Sony HDR-XR520V Handycam Camcorder with built-in GPS receiver[18]
Sony Ericsson XPERIA X1
Sony Ericsson XPERIA X2[19]
Sony Ericsson Aino[20]
Sony Ericsson W995
Sony Ericsson C702
Sony Ericsson C905
Sony Ericsson G705
Sony Ericsson TM506
Sony Ericsson W715[21]
Sony Ericsson W760
Sony Ericsson W995
Sony Ericsson Z780
Samsung Blackjack II
Samsung Galaxy
Samsung GT-i8510 INNOV8
Samsung i8910
Samsung Monte S5620
Samsung Mythic (SGH-A897)
Samsung Omnia
Samsung Omnia Pro 7320
Samsung SGH-i780
Sonim Technologies XP3.20-E QUEST
Sonim Technologies XP3.20-A QUEST
Sprint Navigation
Toshiba TG01
Tracker G400
VZ Navigator
Zoombak tracking devices[22]
Some Sierra Wireless devices
So it appears the IPAD will be able to be used as a mapping solution
Also here
Definition:
Assisted GPS, also known as A-GPS or AGPS, enhances the performance of standard GPS in devices connected to the cellular network. A-GPS improves the location performance of cell phones (and other connected devices) in two ways:
-By helping obtain a faster "time to first fix" (TTFF). A-GPS acquires and stores information about the location of satellites via the cellular network (see almanac) so the information does not need to be downloaded via satellite.
-By helping position a phone or mobile device when GPS signals are weak or not available. GPS satellite signals may be impeded by tall buildings, and do not penetrate building interiors well. A-GPS uses proximity to cellular towers to calculate position when GPS signals are not available.
FollowupID: 690928
Reply By: Member - Richard C (ACT) - Sunday, Jun 13, 2010 at 22:55
Thanks for the replies.
Doug I agree with you to some degree. I have a phone which does lots of things but I just want to use it as a phone and a couple of functions (eg SMS). I have a PDA and a separate GPS device which all works good enough. I run both Ozi and Copilot on it.
My wife has an IPHONE with 3G and I was wandering if it would be any good as a GPS . I know you can get COPILOT on it for navigational software which would be good but don't want to to use it if it will end up costing me money.
So what I was trying to find out does the IPHONE have an inbuilt GPS - which uses the satellites directly with out requiring the 3G network to be available as I don't want to be paying for data transfers - if that makes sense.
Richard
AnswerID: 420703
Follow Up By: olcoolone - Sunday, Jun 13, 2010 at 23:01
NO you don't have to be in phone range for it to work and it is for free as long as you use the GPS software and not the internet.
The Iphone can be used as a stand alone GPS receiver.
YES they uses the satellites directly with out requiring the 3G network to be available.
FollowupID: 690880
Reply By: Charles Jenkinson - Sunday, Jun 13, 2010 at 22:59
The Assisted GPS also refers to the iPhone's ability to use cellular towers to approximate one's position (obviously only whilst within cellular coverage) to decrease the time taken to fix. That would explain why the iPhone takes longer to achieve a position fix in the middle of the desert.
Rest assured that the iPhone GPS (despite, as mentioned, a slightly weak antenna) is actually a very capable GPS. I now have other uses for my old Bluetooth GPS that I ran paired to my old Imate JasJam.
There are other apps available that are far more useful than the Maps program that uses a direct interface with Google. I use a piece of paid software called GPS Kit (by Garafa Software) which still uses Google maps, but can cache them for use outside of 3G coverage. You can record waypoints and tracks, and upload them to the internet, or convert them to a GPX file.
I still use OziExplorer with Hema Maps on a tablet PC for my main navigation (of course with paper backup) but the iPhone has seen me through many trips, including the Gibb River Road, up and down the Powerlines tracks in Sawyers Valley, and a few beach camps in the Kimberley, and north of Lancelin. I still use the iPhone alone when a lighter approach to navigation is desired.
Perhaps OziExplorer will one day be available as an iPhone app?
Good luck!
Charles
________________________
Charles Jenkinson
Perth, Western Australia
Gracie "The Grey Ghost"
1991 Toyota Landcruiser GXL
4.2L Turbo Diesel
358,495km and counting!
AnswerID: 420704
Follow Up By: hl - Monday, Jun 14, 2010 at 07:02
x2
There are some excellent iPhone programs that quite frankly leave dedicated GPS units for dead in terms of features. GPS kit and (my favorite, Motion-X) are very well developed and offer the ability to download free maps, including very detailed topo maps, and keep them on your phone. All you need to do is look at the areas of interest while you're in a wi-fi area (at home) so you won't need to download heaps on the road.
These are not Navigation programs though, and for that you may want to use something like Navigon or Tom-Tom, also available for the iPhone.
It also helps to get around the outrageous charges for map updates for some of the more popular GPS units.
FollowupID: 690901
Reply By: carlsp - Monday, Jun 14, 2010 at 07:24
The I phone capability is not the same as a GPS. We put both side by side and drove around. The GPS unit reads where you are much faster and does not get lost. Quite often the iphone cannot get a reading and give directions in time before the next turn is required. Not godo if you are towing a caravan through the city for example.
If you are lost and only have the phone, it can be great to tell you where you are but using it to navigate around the city as in the Telstra add, it cannot do as well.
If your question was "Can I use my I phone to replace my GPS navigating through the city?" Answer "No"
AnswerID: 420716
Follow Up By: hl - Monday, Jun 14, 2010 at 07:47
could not disagree more.....
My iPhone does everything my Navman does and it does not cost $180.00 to update a map!!!
FollowupID: 690903
Follow Up By: carlsp - Monday, Jun 14, 2010 at 07:58
We were using a Garmin for our test. Unfortunately I cannot comment on a Navman.
FollowupID: 690905
Follow Up By: Charles Jenkinson - Monday, Jun 14, 2010 at 09:31
What mapping program were you using? Were you using just the standard Maps app, or a dedicated piece of mapping/navigation software? You'll probably find that the proper software (ie: GPS Kit, TomTom and the like) will perform quite adequately. Certainly that's my experience with them.
I agree, however, that the pre-loaded Map program leaves a lot to be desired.
Charles
Charles Jenkinson
4.2L Turbo Diesel
FollowupID: 690916
Follow Up By: Member - warren h (SA) - Monday, Jun 14, 2010 at 09:48
Its wierd how everbody seems to have different experiences with the Iphone, I have the 3gs and am impressed with what you can do with it. I have 2 navigation apps Navigon and tom tom, both work extremely well and have it set up so the sound comes through the car sound system, it fades the sound when giving directions and puts it back up when finished, could not be happier. I have another app which gives me internet radio and drive along listening to radio from all over the world, but I do have a fairly large data pack which some of these apps can use a bit of.
I love all this new gear but I must say I was the same as a previous post and only wanted a phone to be a phone, but after seeing an Iphone and what you can do with it buckled and bought one, have not regreted it one bit. I am not interested in the crappy games either but the kids love them.
FollowupID: 690921
Reply By: Member - Richard C (ACT) - Monday, Jun 14, 2010 at 09:15
Thanks again for the replies.
I will have to borrow the wifes IPHONE and have a play with it - if she lets me.
I will still keep my PDA and GPS though as I have invested to much money and time in the maps and understanding how to use it.
But it could be a good one for COPILOT.
The IPHONE and the like have great screen manipulation - much better than the PDA and others I have seen so it would be good if OZI did run on it. I am sure they will look in to it as it is such a big market to miss.
On a slightly different note - would it be possible to get a IPOD TOUCH to connect to an external GPS via bluetooth. This would be a good combination as well.
I will have a look at the map software mentioned above.
Richard
AnswerID: 420729
Follow Up By: Charles Jenkinson - Monday, Jun 14, 2010 at 09:34
Can't tell you for sure, as have never tried it, but I don't think so. Apple are somewhat proprietary with the features they allow programmers to use, which makes it hard to write applications that utilise the FULL capabilities of the iphone.
Using bluetooth GPS requires the creation of a virtual COMM port to a computer. I've never seen an iPhone app that does this, with GPS or another device.
Could be wrong though, so anyone who wants to correct me, please do so.
It would be LOVELY to be able to run these mapping apps on an iPad! Would be a much nicer version of the Tablet PC that I use for navigation...
Charles
Charles Jenkinson
4.2L Turbo Diesel
FollowupID: 690918
Follow Up By: Member - Richard C (ACT) - Monday, Jun 14, 2010 at 10:20
Charles,
Yep the IPAD would be good. I am in the market for a new Notebook or something else and the IPAD is not that much more expensive.
It is such a good interface but unfortunately does not look like I can use my maps.
My wife also has a MacBook which we take when we travel and I started looking at setting it up for maps but once again it looks difficult due to the lack of Apps I want to run.
Oziexplorer will not run on it but a product called Macgps Pro I think it is called seems similar and will read the raster maps.
But I was keen to see if I could get an IPHONE/IPOD working as it is great to use.
You never know what is around the corner with technology though.
Richard
FollowupID: 690925
Follow Up By: mikehzz - Monday, Jun 14, 2010 at 15:57
I have the iPad and all the iphone apps come across via itunes free of charge so no paying twice. You have to buy the 3G version of the ipad to get GPS even though you don't need a sim card in the ipad for the gps to work which proves that it doesn't need the 3G towers for a fix. I do not have a sim card in mine and the gps works fine, actually better than the iphone....must have a better aerial? IPad=great device in my book.
Mike
FollowupID: 690961
Follow Up By: Member - Richard C (ACT) - Monday, Jun 14, 2010 at 17:13
I had a look at Motion-X - are there Australian maps for this. From the web site it does look like a navigational software - ie door to door.
Interesting what was said about the IPAD - it sure would be a good map display.
Will be interesting to see a review of its GPS capabilities,
Richard
FollowupID: 690969
Follow Up By: Member - Richard C (ACT) - Monday, Jun 14, 2010 at 19:48
re IPOD Touch.
If you get a TomTom Car kit for IPOD or IPHONE you get GPS capabilities.
It appears the IPHONE 3G has the inbuilt GPS but the Tom Tom enhances this - I think :)
This does not give you the application software - for this you would need Tom Tom or perhaps even COPILOT.
May be even Motion-x will work as well.
http://store.apple.com/au/product/TY168ZM/A?mco=MTY3ODQ5OTY
If OZI would work on this then it would be a much better solution than the PDA I use.
I guess I just have to keep dreaming.
Richard
FollowupID: 691010
Reply By: Nutta - Monday, Jun 14, 2010 at 22:19
I use motion gps for the iPhone when I'm mountain biking, it logs routes, altitude, speed and more for four bucks.
I've also got an iPad with 3GS and no sim, the gps always seems to know where I am so it must work without sim.
Cheers wayne
AnswerID: 420834
