Winching Question
Submitted: Sunday, Oct 19, 2003 at 20:03
ThreadID: 7932 Views:2432 Replies:7 FollowUps:5
Hi all,
This may be a crazy question, but I'll ask anyway.
I typically only go 4wding with another 4WD, so my list of recovery equipment is minimal (Treads,Snatch Strap, Bull Bag,Compressor,Shovel).
I'm planning a couple of solo trips so I'll nead to add a winch to my kit. So far all the times I have been stuck, I have been recovered from the rear of the vehicle. If I was solo on these occasions a front bullbar winch would not have helped.
Here comes the crazy question;
Is there anyway a bullbar mounted electric winch can be set up somehow to pull you backwards ?? (use of pulleys or something)
Phil P
Reply By: Willie - Sunday, Oct 19, 2003 at 20:45
Not a problem winching backwards with older 4bies. Just run the cable under the truck and winch slowly. If there is a handy tree you can winch sideways and get yourself out that way. Another idea is to buy a lightweight winch(3000lb) and fit it to your rear bumper. I have winched my trucks in all directions with a front mounted winch. You can of course take a set of rope pulleys with you...it is a clumsy way to winch but it will get you out of strife.
Best thing however, is to be careful when you are going solo, and not get in to a silly predicament.
Willie
Never a dull moment
AnswerID: 34386
Follow Up By: Willie - Sunday, Oct 19, 2003 at 21:05
PS Brawn have a portable 9500lb winch in a cradle for all sorts of applications. May be a heavy muther though.................
Willie
Never a dull moment
FollowupID: 24767
Reply By: GOB member vic - Sunday, Oct 19, 2003 at 20:46
phil you can buy a winch that mounts in a fitting like a hayman reece hitch so that it can be used front and back but i dont know what capacity its rated at
steveoimagine a 03 gu 4.2tdin the picture
as i am having trouble sizing the picture
AnswerID: 34387
Follow Up By: mudgutz - Monday, Oct 20, 2003 at 14:04
yeah i saw one of these beasts.......beleive it or not mounted on the rear of a kia sorrento at the sydney4wd show ......looked liked a handy unit.....why you would take a sorrento where it would get bogged is beyond me but thats what i saw
FollowupID: 24808
Reply By: Truckster (Vic) - Sunday, Oct 19, 2003 at 21:38
Depending on your truck, you can mount one on the rear..
Other than that, modify the fairlead roller so that the cable can go under the car without fubaring it. Then winch backwards
AnswerID: 34392
Reply By: Member - DOZER- Monday, Oct 20, 2003 at 08:07
Gday Phil
Turfor in the back is what you need. First time will be the last if you get stuck, but hey, you are self sufficient and able to safely pull at any angle.
There are also winch cradles available that you sling to the bar and pull, but you will probably brake your back getting it out the back.
Think about the picture above and then imagine how you would look after threading the wire back through to the rear :-)
Andrewwheredayathinkwer mike?
AnswerID: 34422
Reply By: Member - Mal - Monday, Oct 20, 2003 at 10:45
Mr P,
Before you get into a"sticky" situation run a strong rope under your vehicle from winch to tow bar and pull it tight and tie off. That way you can pull your winch cable through to the rear easily. When winching, run the cable through a shackle attatched to your tow bar so you get the pull from the centre of the rear of your vehicle and the vehicle doesn't slew sideways.
Mal T.
AnswerID: 34439
Follow Up By: american guy - Monday, Oct 20, 2003 at 13:14
her's one i bet you guys nevers heard of
how about a land lock?
it's my dad taught me that really works
the deal is you can get through the mud hole when thers is nothing to hook your winch onto. ok read closely
first you need a good shovel
then a good bar or pipe or chunk of wood
and most importatly a winch
the next thing you need to do is dig a trench on solid ground. if you can not find solid ground this will still work
dig a trench about two meters long tapering the depth, the shallow end closest to the vehicle and about two to three feet deep at the deepest end. if you are in mud go deeper. next dig another trench about one meter wide to form the cross of a "T" the same depth as the deepest part of the tapered trench. next lay a big chunk of wood or a metal bar or something in the top part of the trench (cross of the T). hook the winch cable on the bar/wood/whatever, then to the vehicle and pull a way.
this may take some effort but when you are alone it won't take long!!
FollowupID: 24804
Follow Up By: mudgutz - Monday, Oct 20, 2003 at 14:17
the american fella must like digging.......how big was that trench sounds like i could get all the anzacs plus a few poms in it..........wouldnt us aussies just use a few star pickets banged in for the job or at worst bury the spare tyre.
FollowupID: 24809
FollowupID: 24810
Reply By: american guy - Monday, Oct 20, 2003 at 21:42
usaly a 6 foot long by 3 foot at the top of the "T" will get the job done you have use your own judgement by at least 3 feet deep
AnswerID: 34525
Reply By: Aaron - Tuesday, Oct 21, 2003 at 00:36
get yourself the front mounted winch, anda hi lift jack. you can do anything then. the high lift jack can be used like a hand winch.
AnswerID: 34547
