HF SB250RC BARRETT NOT TRANSMITTING ?
Submitted: Monday, Oct 20, 2003 at 22:22
ThreadID: 7964 Views:3771 Replies:4 FollowUps:9
Hi all, I have just finished fitting a 2nd hand HF SB250RC BARRETT TRANSCEIVER.
I can hear all over AUS at times, but when I try to make contact I get no response. The question is- when I transmit, should something come up on the LCD display like a bar graph. this is what my UHF does- next to the T.X. digits. Also when I am speaking in to the hand piece-I can still here other people talking as well. Is this normal? Because with my UHF radio when the ptt is held down the conversation is cut off. It is the first time I am trying to use this thing, so I dont know if it is working correctly or I am doing something wrong. The unit is like brand new-no scratches any where. Antenna mast is a TERLIN 24 tap. An.y info would be much appreciated, cheers.
Reply By: Mad Dog Morgan (Vic) - Tuesday, Oct 21, 2003 at 00:42
The radio is not switching into tx mode for some reason. I'm not familiar with the radio, dunno if it has some lock to prevent accidential transmissions or not. Could be a bung wire in the mic or the tx switching either mechanical or diode not operating.My Best Mates
Hooroo
Ray
AnswerID: 34548
Follow Up By: carazy merredin wa - Tuesday, Oct 21, 2003 at 21:04
Thanks Mad Dog Morgan, I now recon the radio is'nt switching to T.X mode, as the bright red light doesn't alter when talking. I hope it is'nt a diode-could be expensive. I am getting 12.7 volts to the transceiver & have a 30AMP HRC fuse at the battery. I would like to check the power draw when transmitting, but my multimeter can only go up to 10 amps.
FollowupID: 24997
Follow Up By: Mad Dog Morgan (Vic) - Wednesday, Oct 22, 2003 at 00:45
No not a serious problem and shouldn't be expensive at all but it needs someone who knows what they're doing to have a look at it.My Best Mates
Hooroo
Ray
FollowupID: 25027
Reply By: koh - Tuesday, Oct 21, 2003 at 10:32
Carazy.. off subject but are you living in merredin?
AnswerID: 34572
Follow Up By: carazy merredin wa - Tuesday, Oct 21, 2003 at 20:05
For 36 years & still here. why do you ask?
FollowupID: 24987
Follow Up By: koh - Tuesday, Oct 21, 2003 at 22:52
because i do too, for 39 years and still here :)
FollowupID: 25024
Follow Up By: carazy merredin wa - Wednesday, Oct 22, 2003 at 20:40
Well Ill be buggered, it is a small world & getting smaller by the minute-with modern day com's. Ill have to keep a eye out for ya, might pass you on the street.
FollowupID: 25087
Follow Up By: koh - Wednesday, Oct 22, 2003 at 23:15
sure is a small world..
any ways for now
Keep Left !
FollowupID: 25127
Reply By: Darryn - Tuesday, Oct 21, 2003 at 11:58
Carazy, check the microphone is plugged in correctly as they can vibrate loose in the socket. Check you are not on a "User Programmable Channel" as you can only recieve on these channels, not transmit. There is a red LED on the control panel which will glow when the set is on, but when transmitting is intensity will vary depending on how you are talking. Contact Barrett in Perth and ask for a manual.
Regd's Darryn
AnswerID: 34582
Follow Up By: carazy merredin wa - Tuesday, Oct 21, 2003 at 20:35
Darryn, the microphone can't be disconnected, however the speaker you can disconnect. I have entered the VKS-737 BASES as follows-channel 150-3995.0khz, 148-11612.0khz, 147-8022.0khz, 146-5455.0khz I don't
know if these are " User Programmable Channels". The red light does glow, but does not change its brightness at all & I have only just noticed that above it, there is a T.X. abbreviation there. I thought it was just for power is on. I was planning to go see somebody, but thought I may ask here first-you never know! Thanks for the info.
FollowupID: 24990
Reply By: Member - Errol (WA) - Tuesday, Oct 21, 2003 at 19:11
Try going to chanel 2 ( 8022 freq ) . thats where you will hear VKS737 at 6pm most evenings . Good idea to join that org , thay cover most of oz and have reguler scedes where you can call in or just listen in to others .Why go overseas when you can ExplorOz
ERROL
AnswerID: 34632
Follow Up By: Member - Errol (WA) - Tuesday, Oct 21, 2003 at 19:17
ps, Listen out on 8022 at 730 am this sat , sun , you mite hear eather me or Peter on . Call sing Whisky 302 or whisky 4502 ( i think thats his callsing ) .Why go overseas when you can ExplorOz
ERROL
FollowupID: 24979
Follow Up By: carazy merredin wa - Tuesday, Oct 21, 2003 at 20:52
Errol, I mostly listen in on the chanel 2 (8002) freq ok, interesting & informative. I will join the VKS-737 org, just as soon as I find out my HF radio works ok & I haven't brought a dud! I plan to travel all over aus so I recon I will be needing it. I will listen out for you guy's, but I can't seem to pick up Perth-if your in that area. I don't know if Im too close, as Merredin is only 270km away. Like the rig set up-a few bucks hey!
FollowupID: 24993
