auto hubs
Submitted: Wednesday, Oct 22, 2003 at 20:31
Member - Kim (mr)
G'day all, I've just put some new
wheels on my patrol (roh villans)and they have a cap on the center so it makes it hard to get to the hubs to go from auto to lock. So i was just wondering if anyone knows of any sort air opp. device or somthing to lock them in. thanksMore drive'n less talk'n
Reply By: Geoff - Wednesday, Oct 22, 2003 at 21:03
Get caps to suit your hubs.
Sounds like you've got caps for a constant 4 wheeler
Geoff
34764
Follow Up By: Member - Kim (mr) - Wednesday, Oct 22, 2003 at 22:03
The caps make up part of the wheel.( And its a good looking wheel toMore drive'n less talk'n
25108
Follow Up By: Geoff - Thursday, Oct 23, 2003 at 12:25
Kim
So they're 'cruiser
wheels then?
Did they ask when you ordered them?
Your options:
Take 'em back and get Patrol
wheels (if that's the case)
Lock the hubs in and forget about them (you probably wouldn't notice any difference anyway)
Get the caps machined to suit your hubs
Put the stockers back on (???!!!???) when you go 4 wheeling
Geoff
25149
Reply By: hoyks - Thursday, Oct 23, 2003 at 13:02
Just leave them set to Auto. If you do some hardcore work and want then locked, then it's a 2 minute job with an allen key to change it (A bit of apain though). The auto setting is good for most work, but if it looks like you may be lifting a wheel, go to locked.
I think I have seen the hub cap with the centre machined out though. You could take them to a machine
shop and get it done for minimal cost.
34850
Reply By: diamond(bendigo) - Thursday, Oct 23, 2003 at 18:10
gday mr kim.
the roh villians should be fitted with the type of cap that the end just clips on.
just have a little screw driver in your glove box and just flick them off.
there should be a couple of little cut outs on the cap to remove.back by popular demand
34879
Reply By: stillthinkinaboutit - Monday, Oct 27, 2003 at 18:52
If you do any serious 4WD'ing with the center caps on they will break and then you don't have too worry anymore. I broke the rear ones on the first trip and the fronts on the next trip, now I have no problems.
35287
