help needed <span class="highlight">battery</span> <span class="highlight">monitor</span>
Submitted: Sunday, Jul 18, 2010 at 19:47
navara07
I have a opposite lock dual
battery monitor hooked up main batt. in No.1 LED shows 100% but does not show the rate of charge it is recieving no green charge led bars. Have not hooked up batt No. 2 as yet may I have to have both wired up to work correctly unsure ????..
http://www.oppositelock.com.au/media/SITE_4/media/images/product/enlarge/4109.jpg
Thank You.
Reply By: Member - Peter W (WA) - Sunday, Jul 18, 2010 at 23:39
navara07
I have one. It has 2 pairs of wires, one pair go to the pos & neg of
battery 1 and the other pair to the pos & neg of
battery 2..They work independently of each other. So long as you have the pos & neg to the correct terminals it should show the charge rate as soon as you start the car.
Mind you I had 3 fail in a very short time..Opposite Lock replaced them and the one I have now has been in the car for about 5 years.
424452
Follow Up By: navara07 - Monday, Jul 19, 2010 at 21:40
All is now good just had to wait till glow plugs turned off then shows charge rate just a little hasty thanks.
695000
