4.2 v 3.0 turbo diesel Patrol
Submitted: Thursday, Oct 23, 2003 at 17:44
ThreadID: 8036 Views:2817 Replies:6 FollowUps:11
Which one is better. I tow a 1450kg camper and intend to fit the dtronic if I get the 3 lt. I need your expert advice please.
Reply By: jeepy - Thursday, Oct 23, 2003 at 18:24
A 3.0L Auto with D-Tronic would tow the best as the auto will mask any lack of low down torque and with the DTronic it wil have more torque than the 4.2. Only problem is how long will the car last? If you plan to keep it only a few years this will give the best bang for buck, if you are looking for something to keep a long time I'd go for 4.2.
AnswerID: 34881
Reply By: Member -BJ (Sydney) - Thursday, Oct 23, 2003 at 19:02
Johnad , We have the 3.0ltd, D'tronic fitted & tow a Kimberley Kamper 3 yrs old 65,000 ks & we love it. Regards Bob
Where to next
AnswerID: 34891
Follow Up By: Johnad - Thursday, Oct 23, 2003 at 23:30
Does the dtronic make a significant difference?
FollowupID: 25236
Follow Up By: Member -BJ (Sydney) - Saturday, Oct 25, 2003 at 10:41
Johnad, the D'tronic stops the turbo lag, increases turbo boost , & someone told me it brings turbo in at lower revs. I think it has a significant inprovement on performance. Regards Bob
Where to next
FollowupID: 25346
Reply By: Truckster (Vic) - Thursday, Oct 23, 2003 at 20:03
4.2 Turbo by a billion light years..
no worries with gearboxes, and other techno shiat that drops like a brides nitey...
Search for 3.0 engine failures, gearbox failures, and its NOT just the early ones.
AnswerID: 34898
Follow Up By: joshinthecity - Friday, Oct 24, 2003 at 00:04
Good one Truckster.
You should know that they both have the same gearbox.
They BOTH had issues with 5th gear when towing at low speed (lugging)
However Nissan has rectified this with a bigger 5th gear. ( I forget how many mm bigger it is), but I've seen the difference in the flesh, At John Robinson Nissan and it IS noticable.
FollowupID: 25238
Follow Up By: joshinthecity - Friday, Oct 24, 2003 at 00:09
Matter of fact, why take my word for it ?
Feel free to contact Adrian Prior, Service Manager. Nissan Rockdale
02-95976040.
He's been working on Patrols since Moses, and is a personal long-standing friend of mine.
Call him and ask him about Patrol gearboxes, and early 3.0 oil starvation. Get the facts. Make your decision.
j.
FollowupID: 25239
Follow Up By: Truckster (Vic) - Friday, Oct 24, 2003 at 00:31
Josh, Ive been around the patrol lists for 3 years, what would you like to know?
There are many more 3.0's failing than 4.2s
I have the facts... Mate also works at Nissan headoffice in the engineering dept..
have a nice day.
FollowupID: 25241
Follow Up By: Pete G - Friday, Oct 24, 2003 at 08:36
Truckster,
The GU2 3.0l has an identical gearbox to the 4.2 GU2.
The ones in 4.2 have been failing as well.
When my 5th gear went I asked to inspect the stripped box. There was an issue with the 5th gear cog where it was splined onto the main shaft. The replacement cog has a longer boss at the spline (about 1/3 bigger). IMHO it was also a problem of manufacturing tolerances where there was insufficient interference in the fit between the 2 components (Ie the fit was not tight enough). Mine failed at 72k's and has since done 70k's without any issues.
The gentleman mentioned above is certainly knowledgable on the subject.
I would comment that the Patrol G/box otherwise is built like the proverbial outhouse.
As for the motors there have been some issues certainly with the GU2 versions which Nissan have honoured - my motor was replaced at 140k's. It does seem that more work is needed to make the 3.0l more bullet proof. As for the size thing - there are thousands of these size motors in the 2-3t delivery trucks doing a mighty job each day. Nissan has to improve matters in this department.
As for towing - the 3.0l will easily handle a large camper - however that said there is a need to keep them spinning above 2-2500rpm or they will bog down big time. (I have the manual)
I concur with other comments re the 3.0l on road being more lively than the 4.2T - have chased a few - the pickup is far better. This is especially true at 100kph. After all apart from the torque band in the 4.2 coming in at 1000rpm versus 2000rpm for the 3.0L the HP and Torque outputs are virtually identical.
Things in life are often a compromise and technology advances. For a new vehicle a 7 grand saving is hard to ignore (plus additional service costs for the 5k oil changes). For people who buy new and run to 100k's then VFM the 3.0l is hard to beat.
As for the problems - well that happens to everyone (eg the 80 series or the Hilux 2.8 etc - I guess that the Customer is now the QA department for a lot of manufacturers)
For long term ownership and serious offroad and towing - yes the 4.2T comes to the fore based on PAST experiences. I do not have any info regarding the longevity of the new intercooled 4.2T and the electronic injection as they have only been about for the last 12mths or so. It is difficult to ignore past performances, however the I/C4.2 is somewhat of an unproven identity. Much the same as one should buy a Commodore because it won Bathurst this year sort of stuff.
If you have any comments to add to this forum for the GU3 3.0l or the GU3 I/C 4.2T, I would be glad to hear them.
Pete G
FollowupID: 25252
Follow Up By: Bonz (Vic) - Friday, Oct 24, 2003 at 17:54
Moses had a 3.0l and didnt have an ounce of trouble with it as I remember.Laterally Literal
Seriously Cerebral
FollowupID: 25299
Reply By: sean - Thursday, Oct 23, 2003 at 20:40
I have had both 3 litre (2000 mod) and 4.2 (2003 mod) in manual. The 3 litre kills the 4.2 in power, acceleration, and ability to hold speed on hills, ESPECIALLY when towing. Mine was standard (No dtronic).
The answer to the question. The 3 litre is better for towing. And I know becuase I towed with mine. I am also not sure if Auto is really better, expecially for heaver loads.
If you want outright reliability, or whatever, the answer may change depending of your requirements.
As for problems, my new 4.2 with only a few thousand on the clock is to go in next week to have the gearbox ripped out under warranty for a bit of probing to find where the noises are coming from. Just hope they know how to put it back together properly.
Good luck.
Sean
AnswerID: 34904
Follow Up By: GUPatrol - Friday, Oct 24, 2003 at 10:54
Sean,
What noises?
Do you mean the kind of grinding noise at low rpm low speed?
If that is what the noise is forget it, nothing wrong with the gearbox or any of the transmition components.
It is a noise all 4.2s made since day one back in 1988 when it was first released in 1988 and it is due to the harmonics of the engine/gearbox combination.
Will
FollowupID: 25261
Follow Up By: sean - Friday, Oct 24, 2003 at 14:16
Will
thanks for that info but unfortanetely not. Dealer says noise is not normal and says box needs to come out. I will let you know.
Sean
FollowupID: 25276
Follow Up By: GUPatrol - Friday, Oct 24, 2003 at 14:25
Sean,
Must be a different noise then, everytime I am on a club trip or something people tell me "something is wrong with your gearbox" re: "the rumble" but it has been there since new and it now has over 155000kms...
Some Landcruisers do it to, the naturally aspirated 4.2 model one.
Will
FollowupID: 25278
Reply By: Member - Kim (mr) - Thursday, Oct 23, 2003 at 21:12
I have the 3lt and its done 85000 kms without missing a beat. No dtronic and it is manual. and i love it. All this talk about engines blowing up and 5th gear going etc is just crap, no doubt its happend to a few, but tell me a car that has no faults.
Well this should get a few people started LMAO..More drive'n less talk'n
AnswerID: 34910
Follow Up By: Billy - Friday, Oct 24, 2003 at 11:00
Kim,
I agree, most cars these days have issues. Component suppliers are under time and cost pressure and so is the factory. It appears it's easier to fix things after the fact.
We have a 2002 3.0Di Auto which performs excellently, and tows a heavy boat and car/trailer combinations very well.
There have been two problems with it, a rattling passenger airbag and a leaking lift pump, both cheerfully repaired under warranty.
Neither of these items are unique to this model and could just as easlilly affect a number of other Nissans, maybe other brands too including almost certainly the 4.2 Patrol.
The engine woes on the early 3.0 Di may have been poor engineering, but given my experience with other new cars over the last few years continuing individual component failures are not unique.
A new '95 EF Fairmont I had went back for an Air conditioner compressor, two thermostats and housings and a tail light wiring loom. This was regarded as a proven model at the time, and basically the same as thousands of Taxi's.
Recently I've had new Alfa's and have had recalls for power steering hoses and ECU re-programming and in the first one the gearbox ECU failed. These bits were all ZF or Bosch, well known euro suppliers.
A mate has had big gearbox drama's in an X5, so it's not restricted to price!
The only vehicle I've had of recent times that was fault free was a '98 Jackaroo. Then the rocker cover leaked after a valve clearance check and diff oil pee'd out after they put 75W90 in it not 140W. Goes to show, if the car don't get ya, the gease monkeys will!
Regds
Bill
FollowupID: 25262
Reply By: Notso - Friday, Oct 24, 2003 at 08:19
I Have a 3.00 TD July 2000 build and have had numerous problems with it Top gear went in perth after 35,000 ks. Nissan rebuilt the box. at 55,000 they realised the wrong parts had been used and rebuilt it again, this time with new spec bits. Computer replaced, air flow meter replaced, 4 injectors replaced. Still got it but don't really know why except that better the devil you know I guess. Great tow vehicle.
AnswerID: 34939
