Too hard suspension
Submitted: Thursday, Oct 23, 2003 at 23:46
ThreadID: 8044 Views:2505 Replies:6 FollowUps:1
Hi!
I have another problem with my Pajero mentioned PostID: 8038. I satisfied with the standard suspension when traveling outback but cause pain in my back in the city especially in Budapest town of pothole. Sometimes medicin necessarry. May i change softer dumping or/and spring or fell the air off from tyres?
Thanks in advance
Reply By: joshinthecity - Thursday, Oct 23, 2003 at 23:56
If it was me, I'd be inclined to go to a suspension specialist to get your dumpers and springs professionally diagnosed. But DO NOT fell too much air from the tyres. You could find them coming off the rims.
J.
AnswerID: 34930
Reply By: ontopic - Friday, Oct 24, 2003 at 01:44
Auto you should have a chat with previous poster dlatus as you speak
the same language.
AnswerID: 34934
Reply By: GQfisho - Friday, Oct 24, 2003 at 07:49
There's always adjustable shockers from rancho and tough dog. approx $400/pair.
Haven't tried any of them but being adjustable they should give you best of both worlds.................
AnswerID: 34937
Reply By: Les from Lovells Springs Central - Friday, Oct 24, 2003 at 15:01
Why not contact Lovell's Springs and check out what they can do for you, they can put together a kit that will be what you want.
AnswerID: 34983
Reply By: phil - Friday, Oct 24, 2003 at 15:39
How much air pressure do you have in the tyres?
If it is over about 30psi it may be too much around town (and on dirt roads!)
AnswerID: 34985
Follow Up By: carazy merredin wa - Friday, Oct 24, 2003 at 20:33
Phil, i agree. Because my lower back is dicky, I've experimented with tyre pressures & I can tell you that 4 psi lower pressure can make the difference between a harsh ride & a plush ride. I now personally run with about the lowest pressure I can-28 psi.
FollowupID: 25311
Reply By: Mickl - Friday, Oct 24, 2003 at 20:14
If the only problem the suspension is causing you is a pain in the back why not consider a suspension seat?
AnswerID: 35019
