How corrugations feel in the caravan
Submitted: Thursday, Aug 19, 2010 at 09:39
Member - Carl
In a week or so heading down the
Great Central Road from West to East. This 1100 kilometers of gravel and some parts are very corrugated.
So we all know how you vary the vehicle speed to suit the wheelbase on different corrugated sections. Faster or slower etc. The tow vehicle is a F250 with a long wheel base but the caravan Kedron (or any caravan) has a much shorter wheelbase. Although both are built for toughness, what speed is right for one may not be right for the other.
But in the bigger picture I am seeking ideas on how to get a feeling of how the corrugations are effecting the van. Thought of installing a camera inside the caravan, something like a pedometer or a vibration sensor.
Someone on the
forum might have put some brain power into this solution before. Interested in different ideas.
Reply By: Fiona & Paul - Thursday, Aug 19, 2010 at 11:46
G'day Carl
I reckon if we could see what goes on inside the caravan on the really rough sections we wouldn't go there anymore and I have enough trouble spotting bad sections ahead of us.
We tow our single wheelbase and ordinary Compac 402 just about anywhere, except for areas where there are deep spoon drains, rutted areas, etc, because I have to take care when driving through gutters into most petrol stations. If necessary when the road is bad enough I will travel at 5kph (does not happen very often) as I know how much the van is being shaken about and I want to minimise my tighten the screws and
check the windows maintenance after every major section.
In June we travelled north from
Balranald up through and around Mungo NP, to
Pooncarie and
Menindee on the western side of the river (much longer) and then up to
Wilcannia on the western side of the Darling and it was very rough (for us) for about 40% of the trip but two coffee stops and a few photo stops made it OK for me, on the other hand SWMBO wants to kill my best mate from
Menindee who assured us the road was great. I would not want to follow me for any distance on the gravel.
Out biggest problem will always be those travelling 100kph + in the opposite direction. We spoke with one guy with a big solid off-road type van and big Toyota and they had travelled from way up north 800+ kms, dirt all the way around 110kp and a smooth trip - he spent the first 5 hours in
camp (dark) fixing stuff up. He was not a happy man, I didn't ask any questions and he didn't want a beer.
I get worried every time we go for long trips on the dirt but I am prepared to slow right down (which sometimes makes it seem worse) so we can see the
places we want to see.
Paul H
427682
Reply By: Member - mazcan - Thursday, Aug 19, 2010 at 13:28
hi carl
if you mounted a camera in the van i doubt that you would get the results effectively
as the camera mount would have to be fixed to the floor or some where else that was a stable position
and then the camera would be vibrating and bouncing in the same way as everything else so you would only see possibly the things that were jumping around loosly
like someone mentioned the only way you can really get to know is ride in the van for a few k's and personelly monitor it with your own eyes
i actually did this while going around aus in 1980 on a rough road up north to find out why certain things kept moving and why a door kept coming open and also where the dust was entering
i trusted my wife's driving who was born and bred on gravel roads
by doing the above i solved several on road problems and was able to resolve it in total the above problems mentioned using a powerful torch i was able to open the cupboards etc and see where the dust was pumping in
i did it a second time to double
check both times on very bad corregations
our trip was much more enjoyable afterwards
i must admit it 's not for the faint-hearted
but at the time the dust entry was cheesing us off and i was determemed to stop it and the other things as
well
as they say desperate men do these thing and before someone says i'm an idiot or broke the law
i was aware of that but took the risk and got results
so carl
if you really want to know the quick answer
trust your wife and do it and i might mention i did'nt have a hand held cb we did it for a measured 5km's each time at full speed so nothing was left for the imagination
so cheers from a living dare devil
curiosity kills the odd cat????
are you the odd cat??????
427698
Reply By: Motherhen - Thursday, Aug 19, 2010 at 16:53
Hi Carl
Different tyres pressures will also get different results. We have had a couple of instances of cordial escape out of upright unopened bottles, then find its way out of the cupboard and spread all over the caravan floor. I still cant work out how it gets onto the lino which is an add on in the interior of the van only, not the cupboards which were built on top of the original which was laid across the whole floor. Likely to happen when the corrugated stretch is not long (eg nearly to our
camp spot), getting late and don't want to put down the tyres for the short stretch and not really expecting to do this run tonight, so stuff left all over the caravan seats to land on the floor amongst the sticky goo. Oh, and it is a
bush camp so doesn't have water. Remedy - don't take cordial!
Seriously, if you know the result, will it stop you taking the caravan on the roads you bought it for? Just take it easy, be alert for sudden bumps or washouts and enjoy the ride.
427736
Reply By: pmk03 - Thursday, Aug 19, 2010 at 18:43
What Motherhen said:
"Seriously, if you know the result, will it stop you taking the caravan on the roads you bought it for? Just take it easy, be alert for sudden bumps or washouts and enjoy the ride."
I think you over analysing it...... Just relax & enjoy. Drive to the conditions.
These days the trips are getting so complicated, what happened to the days when we travelled alot simpler (is that a word?)
PMK
427746
Reply By: Member - Carl- Thursday, Aug 19, 2010 at 19:37
Thanks everyone.
I have tried many of the suggestions already.
Sat in the back while my wife drove back from
Millstream NP and descovered that the fire extinguisher needed to be better mounted. Also the glass round thing in the microwave made a terrible racket. The thried thing was the oven door rattled.
The F250 just skips over corrugations but I feel that I might be killing the caravan
suspension. Since posting this I have descovered on the interent special instruments, that give a digital readout in the cab.
I will do more research on this and make a post in a few weeks. The hard thing is getting that speed that is best for both.
427751
Follow Up By: Motherhen - Thursday, Aug 19, 2010 at 20:01
"The hard thing is getting that speed that is best for both."
If you found that Carl, it would probably take you all year to get to the NT border.
Mh
698414
