v6 fourunner fan bearing
Submitted: Sunday, Oct 26, 2003 at 08:38
Member - Neil (N.S.W.)
Hi all,
Just finished replacing two aftermarket cam seals on me 4by, but notised a bit of movement in the bearing for the fan. The housing looks the same as the old
water pump type without the impeller at the rear also has lrge flat area with legs/spacers to allow the timing belt to run behind it, it looks like the bearing may be pressed out? i hope so because toyota quoted me $1100 for the whole housing.
Could any1 pls shed some light on this topic thnks.
mezy GONE WOOP-WOOP
Reply By: Eric from Cape York Connections - Sunday, Oct 26, 2003 at 10:10
Mezy I dont know about the above but if you start doing out back on corrugation driving take a spare idler arm with you . If you bust one on the track you aint got no steering. We always suggest to our tag alongers who own the same truck to pack one. This year we had one go and it took about 1/2 hour to replace.
All the best
Eric
4x4 tag along adventuresCape
York Connections
35134
Follow Up By: Member - Neil (N.S.W.) - Sunday, Oct 26, 2003 at 10:16
eric,
thanks for that info
it will be a while before any of that just started a new job bleep load of hours not much time off but will have to make it i spose.
mezy
GONE WOOP-WOOP
25389
Reply By: Member - Raymond - Sunday, Oct 26, 2003 at 20:39
Neil, I had the same problem last year with my v6 4runner. I had the same idea as you about getting it pressed out. It was too fragile however, and when fitted back in it just broke down completely. In the end I had to bite the bullet and bought a new one from Toyota. I ended up spending about $400 to try to get the original pressed out and still had to
fork out the big bucks for a new one in the end.
For your reference it took Toyota about 6-8 weeks to get me a new one, so that meant 6-8 weeks with the 4runner idle. I wouldn't start working on it without knowing that Toyota has the part in stock in Australia.
Ray
35172
Follow Up By: Mickl - Sunday, Oct 26, 2003 at 23:59
$400??? just to remove the pump and press out the bearing??....I gotta bump up my hourly rate....
25432
Follow Up By: Member - Raymond - Monday, Oct 27, 2003 at 14:18
Mate, that's
Canberra prices for you.
25474
Follow Up By: Member - Neil (N.S.W.) - Saturday, Nov 01, 2003 at 08:06
Ray,
thnks for the bad news i was sure it could be pressed out how much did it cost for the new housing and at what km's was this done. Srry i hav'nt replyed earlier ive been working in syd.
Mezy GONE WOOP-WOOP
25905
Follow Up By: Member - Raymond - Saturday, Nov 01, 2003 at 13:06
Neil, the housing was around $1200 from Toyota. They had to order it in specially. It happened last year and from memory, it was around the 150 000km.
My machanic installed it for free as the whole trying to cut corners was his idea and it didn't work out.
25913
Follow Up By: Member - Neil (N.S.W.) - Sunday, Nov 02, 2003 at 08:26
Ray,
Thanks for the info, that sounds like very low k's for that prob my k's are at 225000
well i hope i can getaway with this for a bit longer yet
i dont fancy spending $1200 on a new one just yet.
Mezy
GONE WOOP-WOOP
25945
Follow Up By: Member - Raymond - Sunday, Nov 02, 2003 at 10:56
Good luck with it mate, I'd probably look to replace it before a major trip. As I mentioned earlier, it too almost 6 weeks for Toyota to get one in. That was after telling me that they had one in the country which turned out to be a computer error.
Ray
25953
