Nissan Xtrail into Bendethera
Submitted: Tuesday, Oct 28, 2003 at 15:26
Treading Lightly
Hi.
Could standard Xtrail loaded with 2 aduults and
camping gear venture into
Bendethera via
Braidwood?
Is there a better (safer) way to enter?
JDLife is to good to be dead.
Reply By: GUPatrol - Tuesday, Oct 28, 2003 at 15:53
JD,
The best (easiest way into
Bendethera) is via
Moruya.
I have never driven an Xtrail so can't tell you but it would be on the limit without low range, but it all depends on the track conditions at the time you are there...
Coming from
Moruya there are a couple of steepish bits as you get into the
Bendethera valley but if they too steep for the Xtrail but smooth you may be able to get a runup, if the track is rough you may have a bit of trouble...
When are you going?
Will
35418
Reply By: Truckster (Vic) - Tuesday, Oct 28, 2003 at 17:53
remember you may get in, but if it rains all night, you maynot get out...
Specially on road tires if its slimey.
35432
Follow Up By: flappan - Wednesday, Oct 29, 2003 at 11:43
In an X Trail or the like . . . yep most likely Truckster.
I "had" to come out via
Moruya on Saturday night in the pooring rain, and made it easily (had AT's on), and some Pathfinder guys came out next day with HT's on, and made it easily enough.
Would be a different story with constant rain over a couple of days.
25684
Reply By: GaryInOz (Vic) - Tuesday, Oct 28, 2003 at 18:24
If you do go in, get some DECENT recovery points installed. The vehicle tie down points are NOT strong enough to use with snatch straps. If the point at which a santch strap is attatched to your car fails, you can be very sure the person pulling you out will NOT be impressed with the imprint of the part of the front of your car in the tail of theirs!
35442
Reply By: Tony - Wednesday, Oct 29, 2003 at 07:37
The steepest part on the
Braidwood side is a downhill just before the valley floor and a rouigh bit near
Dampier Trig, with care you will get in there, but as Truckster said a bit of rain and your there till it dries out.
If you are on your own you are better off going down through Majors
Creek.
35518
Reply By: Time - Wednesday, Oct 29, 2003 at 08:27
I have seen Subarus go into the valley without any problems via the
Dampier Trail , so as said above if it is fine weather then there should be no problems,
The note about recovery points is also valid. I know my fellow club members would not even try to recover anyones vehicle unless it had a dedicated recovery point. Too much potential for damage to both vehicles.
Buggerlux
35523
Reply By: Patrol22 (Queanbeyan - Wednesday, Oct 29, 2003 at 08:45
Short answer is NO! Others in my area have had to retrieve a number of softroaders with blown clutches trying to climb out of Bendethra - lots of sickly smelling smoke in the air (from the clutch that is). It simply isn't worth it especially if there has been a shower of rain.
35527
Reply By: Member - Colin (ACT region) - Thursday, Oct 30, 2003 at 00:02
From a Subaru owner.
I don't know anything about your X-
Trails capability but - there is one 'difficult' spot coming in from the West. A 'steep/deep rocky speed bump' which needs a little caution and some momentum - it is about 1/2 km ?? before
Dampier Trig. Each time I have been to
Bendethera this one catches me out, it is washed out and I usually pick the wrong 'line' of approach.
The rest of the tracks are OK, as others have said some bits may be slippery if it has rained and after heavy rain the
creek X's in the valley should be treated with caution.
The Club was there a few weeks ago and did the 'Valley Circuit' via Minuma and Mongamulla FT's. These tracks are steep but have a good surface - we had 2 standard Foresters and a GT Forester (no low range) - all got around OK.
Good luck
35661
