Toyota Hilux dual cab
Submitted: Monday, Sep 20, 2010 at 21:35
ThreadID: 81451 Views:9481 Replies:5 FollowUps:4
While out at the Birdsville races 2010 I saw a duel cab Hilux with a bent chassis just in front of the rear wheels, then in Birdsville I saw pictures of 2 others with the same bend in the same place. Just wondering is this a common affliction with the Hilux duel cab? The car I saw my self was less than 9 months old the owner told me.
Reply By: Member - Marc Luther B (WA) - Monday, Sep 20, 2010 at 21:59
Hi Peter K
I have a 2000 Dual Cab Hilux, and people have told me that it appears to have a bent chassis, but upon closer inspection, they realised it was the "wishbones" of the Indepent Front Suspension that made it appear so.
This may be the case with the vehicles that you haver seen, or they may be bent. Just a thought for you.
Why travel overseas, you could travel Australia your entire life, and not see it all.
AnswerID: 430914
Follow Up By: Fab72 - Tuesday, Sep 21, 2010 at 12:51
The bend appeared in front if the rear wheels, no where near the front wishbones.
Could this be the super SWB version????
FollowupID: 701731
Reply By: Muntoo - Monday, Sep 20, 2010 at 23:33
Pretty much every dual cab ute is prone to this happening.
What causes it is usually a heavy trailer/camper on the rear and air bag springs. The heavy weight on the rear and the caft that the springs are acting like a lever, or like seesaw if you like. Has been alot of dual cabs with this happen, and all have had airbags.
AnswerID: 430917
Reply By: StormyKnight - Tuesday, Sep 21, 2010 at 21:04
I'm guessing that because they have a tray rather than a full body as such, the point of flex is between the tray & the cab...the full body of a wagon might strengthen & reduce the flex of the chassis at this point or at least share it over a greater area.
I assuming that the chassis would be very similar to say a Prado & I haven't heard of the issue like this with them....
AnswerID: 431005
Reply By: Flynnie - Wednesday, Sep 22, 2010 at 00:13
Another factor sometimes is the trays are not well engineered and put extra stress on the chassis. I have heard this can happen if the tray is too rigid. The tray needs to flex.
Flynnie
AnswerID: 431024
Follow Up By: Member - Peter K (QLD) - Wednesday, Sep 22, 2010 at 07:04
In all the vehicles they had trays. but the one I saw on the road was a custom made trades type/camping tool box. I don't know if the cars had airbag helper springs. But I was a little surprised to see such a so called well engineered vehicle in this state..
FollowupID: 701800
Follow Up By: tim_c - Wednesday, Sep 22, 2010 at 22:44
Even the best engineered vehicle still has a limitation to how much it can safely carry (GVM) - it may well be that the vehicle is not designed adequatey, but the topic comes up every now and then and I'm not alone in suspecting that many travellers are exceeding the rated GVMs - if that's the case, you really can't blame the manufacturer if the vehicle can't cope with a load the manufacturer has already stated it can't cope with.
FollowupID: 701891
Reply By: Member - Phil G (SA) - Wednesday, Sep 22, 2010 at 12:41
Very common - and just to add that it mostly happens with dual cabs but not single cabs because of poor weight distribution - dual cabs have very little weight in the cab and then a heap of weight behind the rear axle.
Then they get a tray thats a bit longer and hang the spare wheels off the rear and put in an extra 150 litres of diesel because their fuel tanks are woefully small....and then they fit the airbags because the rear end sags.....and then they tow a trailer with 200kg ball weight over some rough stuff.....and it lacks the extra rigidity of a full body.... so then out in the desert they notice a widening gap appearing between the tray and cab.The gap widens as the chassis bends or cracks and then it goes no further because the tailshaft is pushing into the diff creating problems there....
Very costly errors - not really a manufacturing defect because the vehicles are often over GVM or tow ball limits and are inappropriately loaded with modified suspension.
So if you are a dualcab owner and want to prevent this from happening, you need to keep the heavy stuff (water and fuel) forward of the rear axle and take measures to reduce the towball weight from anything you tow..... or else upgrade your vehicle.
AnswerID: 431057
Follow Up By: Barry01 - Saturday, Sep 25, 2010 at 20:11
i have a 2003 hilux dual cab with a tub liner;one day went over a big nasty bump; the tray liner left a dent in either side at the rear of the cab ;was only carrying about 200 kilos;another bill bye barry
FollowupID: 702156
