Monday, Oct 11, 2010 at 10:38
Hi Geoff
The RAPS is only around $119 (plus postage) for a complete Waeco purpose built kit with the required cable size to run your fridge/freezer. It comes complete with everything you need and is transferable between vehicles if you decide to sell or need to run it in another vehicle. I am just about to go and remove
mine from my old 90 series Prado ready to install later this week in my 'new' 120 Prado.
I do know of an Exploroz Member who sells 4WD/RV gear and Waeco products. Not sure where you are but he is in
Gold Coast area but can post out anywhere. I found him extremely helpful and his advice was great for me. If you decide you would like his details let me know.
Engel also make one for their fridges and I have seen these in Repco but cost a little more and have their own plugs on them. I like these Raps as you decide if you want to use the Hella fitting which locks the Waeco plug into position so it wont fall out, or use the cig fitting or even use that for something else. It is switchable by pushing a button on it for constant power or on/off with engine and cuts out when voltage is low in either mode.
Have a look here:
RAPS UNIT
If you are in SW
Sydney you are welcome to look at
mine, Cheers....
703455
