Another dual cab bent chassis
Submitted: Monday, Oct 11, 2010 at 17:05
ThreadID: 81850 Views:21318 Replies:15 FollowUps:25
just been reading about another dual cab with a bent chassis on another forum, this one being a Mitsubshi MN Triton.
happy reading....
http://www.4wdaction.com.au/forum/viewtopic.php?f=7&t=99859
Reply By: Member - Tour Boy ( Bundy QLD) - Monday, Oct 11, 2010 at 17:19
Sorry to hear about this mate,
I wish all the best in the fight you are undertaking.
2015 Fortuner
Had 72 cruisers in my time
AnswerID: 432713
Follow Up By: rumpig - Monday, Oct 11, 2010 at 17:32
not my vehicle, just one i was reading about
FollowupID: 703476
Reply By: Dave(NSW) - Monday, Oct 11, 2010 at 17:31
That looks like a lot of weight hanging past the rear wheels.
GU RULES!!
AnswerID: 432717
Follow Up By: Graham & Ann - Monday, Oct 11, 2010 at 20:31
Sure is......with the wheels & the camper ball weight.........thats a big load hanging way back there.
FollowupID: 703498
Reply By: Member - Tezza Qld - Monday, Oct 11, 2010 at 18:44
Sorry to see this kind or thing happen.
Still it reinforces my belief that heavier leaf spings are fine but when air bellows are also added the strain on the chassis usually has detremental results.
Hope he has a good result with Mitshubishi but I doubt it
Cheers Teza
AnswerID: 432727
Follow Up By: Ozhumvee - Monday, Oct 11, 2010 at 19:27
Unfortunately what Tezza has said is right, beefing up the springs is one thing but it does place that additional load on the spring mounting points which are designed to take it up to a point. Fitting airbags/bellows as you have done places the weight at a point on the chassis, which it was not designed to handle, the result is chassis failure as you have found.
Sorry but I'm not surprised that Mitsubishi refused the claim.
Ask Mitsubishi what the off road (ie off bitumen) carrying capacity and towing capacity is, most manufacturers avoid giving these sort of figures but on Toyota's it is typically near the unbraked towing capacity which is 750kg's.
On our outback trip this year we saw several utes of different makes with damage like yours after travelling on corrugated dirt roads towing a camper trailer or van and a load in the back.
We've also seen them in previous years and will continue to do so I'd imagine as people seem to buying utes to replace what would have been traditionally a cruiser or patrol job.
FollowupID: 703486
Follow Up By: Member - Ian H (NSW) - Monday, Oct 11, 2010 at 20:27
This result is hardly surprising. With all that weight behind the axle the only possible failure happened. The load should always be directly and evenly placed over the axle otherwise with the engine/gearbox at one end and the load (even if at or under max allowed) at the other what else could happen.
I have long said that dual cabs should have 600 mm added to the wheel base to get the load where it belongs.
It is not surprising that Mitsubishi refused the claim but I still feel a bit sorry for him.
Sometimes common sense dictates what is right and the rig setup certainly failed the "common sense test".
FollowupID: 703496
Follow Up By: TerraFirma - Monday, Oct 11, 2010 at 20:28
Yeah spot on Ozhumvee. And yes the corrugated stuff is causing problems.
FollowupID: 703497
Follow Up By: Road Warrior - Tuesday, Oct 12, 2010 at 11:39
This happened to a member on Ford Forums, he had a Falcon 1 tonne ute and then fitted a trade service body to it but it was mounted to the chassis at the extreme front and rear of the ute's chassis rails with no mounts in the middle to distribute the load, then he went and fitted air bags which point loaded the chassis rails right in between where the service body was mounted. End result - bent chassis.
FollowupID: 703555
Follow Up By: Axle - Tuesday, Oct 12, 2010 at 18:54
Hi Guys, I'lLL say this till the cows come home, In utes Landrover had the right idea", wiith the 130,(130in) wheelbase!, the load is more over the rear axle, and makes a hell of a difference. Im amazed the Japs haven't caught on to this poor weight distrubution that most of, or all of their utes have including the toyota and nissan 4bys.
Cheers Axle.
FollowupID: 703571
Follow Up By: TerraFirma - Tuesday, Oct 12, 2010 at 19:57
Memo to the Japs, straight from an Axle, weight distribution is the key, afterall an axle should know..! Lol..
FollowupID: 703577
Follow Up By: Axle - Tuesday, Oct 12, 2010 at 20:22
LOL!
FollowupID: 703578
Reply By: Flynnie - Monday, Oct 11, 2010 at 20:36
On the other forum the owner argues fairly persuasively that it was correctly loaded. When I saw the two wheels way out the back I jumped to the obvious conclusion of too much weight at the rear. This may not have been so. As writers on the other forum have suggested the engineering explanation is more complex.
However one thing is certain, some combination of forces, loads, twists, flexing jolts etc stressed the chassis beyond its limits.
Moral of the story. If you want to travel loaded up like that bloke was, get a heavier capacity vehicle like a Landcruiser or Patrol and be spared the worry of when a bent chassis will happen to you. Forget the dual cabs, They are not the right tool for that job.
Moral two. If using a lighter vehicle pack even lighter and tow nothing and have an enjoyable holiday.
Flynnie
AnswerID: 432742
Follow Up By: ross - Monday, Oct 11, 2010 at 23:14
He may have been under the max load ,but these figures are for on road usage.
Trailers,sanddunes,spare tyres,corrugations have all helped kill this Triton.
FollowupID: 703516
Reply By: CJ - Monday, Oct 11, 2010 at 20:42
All explanations above are feasible.
But even then, one would expect that the chassis of all things have a safety factor engineered into them to avoid this kind of damage?
CJ
AnswerID: 432743
Follow Up By: mullyman - Monday, Oct 11, 2010 at 20:53
Mitsubishi's saturation advertising campaign has been telling us how bloody tough these fakes have been for ages. Get a Defender and do things properly.
FollowupID: 703502
Follow Up By: TD100GXL - Monday, Oct 11, 2010 at 22:48
Mullyman, I was at Dalhousie a few weeks ago and met a guy in a 130 defender who had just come fro Chambers Pillar and had suffered a bent chassis on that trip. He had hit a nasty bump though and was towing an offroad camper. I was very surprised as if any dual cab is built tuff it would have to be a 130.
FollowupID: 703515
Follow Up By: Pete Jackman (SA) - Tuesday, Oct 12, 2010 at 00:11
We must have been at Dalhousie at the same time - was this the Defender with the HF auto tune on the RHS of the cab? I had a chat to him and ran into him and his family at William Creek camp ground and again at the mound springs near Coward Springs. I didn't have a close look but it looked like it had bent just in front of the rear wheels. He said he hit a washout at about 30km and the shunt from the trailer did the damage.
Pete
FollowupID: 703519
Follow Up By: TD100GXL - Tuesday, Oct 12, 2010 at 10:00
Pete,
Sounds like the same vehicle, I think his name was Rob. I didn't have a close look at the vehicle as we were chatting down at the springs but they said there was an obvious widening of the gap between the cab and the canopy towards the top. Your description of the circumstances also match. They had planned on crossing the desert but were having second thoughts after the damage. We arrived at Dalhousie on the 20th Sept and left on our crossing on the 22nd. What a brilliant time to be visiting the area.
Cheers, Stuart
FollowupID: 703547
Follow Up By: Pete Jackman (SA) - Tuesday, Oct 12, 2010 at 21:55
Hi Stuart,
That was him.
I think we arrived at Dalhousie on the 22nd so we probably just missed (I had lost track of the date by then!). The Defender was visibly bent. The chassis had a bend somewhere between the back of the cab and the rear axle.
The country was fantastic.
Pete
FollowupID: 703589
Reply By: Member - Boo Boo (NSW) - Monday, Oct 11, 2010 at 20:44
I am going to presume that this situation does not apply to a single cab/chassis with a tray and canopy.
Am I correct?
AnswerID: 432744
Follow Up By: Flynnie - Monday, Oct 11, 2010 at 21:21
Was visiting an electrical workshop one day. One of the blokes radioed in he was returning to the depot with a cracked chassis. It was one of the single cab 4X4 turbo 4 something or others. Did not take much notice. I did see it when it came in. Looked way overloaded.
If you keep to a reasonable load and reasonable speed for the conditions a single cab should not suffer this problem. Touch wood!
Flynnie
FollowupID: 703509
Follow Up By: Member - Tour Boy ( Bundy QLD) - Tuesday, Oct 12, 2010 at 09:47
Image Could Not Be Found
2015 Fortuner
FollowupID: 703545
Follow Up By: Member - Phil G (SA) - Tuesday, Oct 12, 2010 at 19:09
People with single cabs load the heavy stuff foward of the rear axle.
People with twin cabs load the heavy stuff in the tray which is mostly behind the rear axle, and this causes the bends/cracks we see. So we don't see it much on single cabs.
In addition you have to consider the body and how it helps the strength of the chassis. The body of a stationwagon helps prevent the chassis from bending because it runs the full length and stiffens it. The dual cab has a separate cab and tub which are not connected, so they are free to bend at this point.
And why don't they bend further? The tailshaft jams tight between diff and transfer case that prevents any further bending.
FollowupID: 703573
Reply By: OREJAP - Monday, Oct 11, 2010 at 22:53
There was a story awhile ago in a 4X4 Forum about a Hi Lux owner in NSW who cracked the chassis on the Tojo when he went over a wash out hump to fast & becasue he had left his tow hitch in & told the dealer this Toyota refused to cover him for warranty claiming negligence on behalf of the client. $2200.00 it cost him to fix the Hi Lux. UNbreakable.....NOT!!
AnswerID: 432753
Reply By: Joe n Mel - Monday, Oct 11, 2010 at 23:01
i do kinda feel sorry for them ...but.... they are after all a weekend 4wd made for kids and shopping and work and maybe a quick weekend away with kids ........
Looking at the pics i do ask to have a good look at the tray mounting points as they are designed for leaf springs ONLY and you add air bags and the pressure points move to the top mount of the air bag and no load from the tray is pushing down directly above it so it flexes and bends in all the wrong places, if a "bracket" was placed right above the air bag the tray (and load) would would push down on the "bag" and not "offset" to the bag................. look at the way the springs hammered the chassis because of being way overloaded ..... if i made this car i also would not offer and warrenty .............
we looked long and hard for years for a suitable car that could take us to our work and back and that is in very remote places, we drove hilux's n nissans and heaps of other (work cars) and not one had any reasonable room in the back for kids (now 3) and just did not "feel" strong enough for 4wd work, after working in Tom Price for a few years we opted for a "converted" HZJ75 and never looked back..................
AnswerID: 432755
Reply By: SDG - Tuesday, Oct 12, 2010 at 01:09
Just a thought in regards to weight, I drove over the weighbridge at the tip the other day, and noticed my Patrol was 2.66T. That was empty. from my understanding GVM is 2.8. 150litres fuel, camping gear, water, etc will soon bring it close to being the limit, if not over. How many of us are overweight when travelling without realising?
AnswerID: 432768
Follow Up By: Joe n Mel - Tuesday, Oct 12, 2010 at 01:25
most, if not all ........
FollowupID: 703526
Reply By: Alloy c/t - Tuesday, Oct 12, 2010 at 09:13
Claims still 45kg UNDER GVM , love to know what weigh bridge he used as its obvious from the pics that its overloaded , just the two spares+bar and arial would bring close to the max let alone hanging a kk of the back , yeah people will scream that the trailer has ONLY x amount of ball weight , ever have it weighed ? Multiply that ball weight by a factor of 4-5 on bumps and corrigations ,
AnswerID: 432779
Follow Up By: landseka - Tuesday, Oct 12, 2010 at 09:37
It is sold as a (or near) a 1 tonne ute. The spares, bar and aeriel are nowhere near 1 tonne.
FollowupID: 703543
Follow Up By: Alloy c/t - Tuesday, Oct 12, 2010 at 13:27
Landseka , MAX payload is 960kg from a dry kerb weight of round 1800kg , standard fuel and oils aready takeoff 90kg or so , he had extra longrange tanks , take off another 100kg or so, driver/ passenger/s 140-300 kg , extra bar work+ tires 90/100kg ,there youve got 50%of your allowable weight already , throw in the canopy 50kg and all the gear in the ute well your on the limit , then add a kk pushing 160 odd kg onto the towbar on corrigations where the down force on the towbar is trippled and quadruppled something has to give.
FollowupID: 703560
Reply By: The Landy - Tuesday, Oct 12, 2010 at 11:10
The problem of claiming from the manufacturer under a warranty is that you are up against a company that will have stress tested not just the chassis to extreme’s, but all the associated equipment in its entirety and they will have all the data, and the firepower to refute claims such as this. And that isn’t to say they don’t have a problem, but the chances are they don’t. The cost of getting it wrong normally ensures they get it (mostly) right and the cost of defending themselves against individuals is small versus having to do a total recall, so they will defend to the ‘hilt’ and make sure they fix the problem in later versions.
A look at the posts in this thread, and also the other forum, highlights just how ambiguous it all becomes and how individuals who believe they have a rightful claim, whether they do is another thing, are up against it when it comes to the proof. Throw into the mix after-market accessories and your case is weakened substantially. In the end the cost of arguing your case would probably outweigh the cost of fixing it.
Which highlights a very important consideration when purchasing any vehicle, but especially new ones......make sure it is going to meet your requirements and make sure you understand any warranty implications for after-market accessories.
And having said that, I do feel for the person involved, but I suspect this will end up being a costly experience.
Cheers, The Landy
AnswerID: 432786
Reply By: Member - Phil G (SA) - Tuesday, Oct 12, 2010 at 12:54
Have a close look at his photos, and he has also fitted two aftermarket fuel tanks - a 130 litre auxillary behind the axle and a 120 litre replacement forward of the axle.
He's got a huge amount of weight behind the rear axle.
AnswerID: 432790
Follow Up By: Member - Phil G (SA) - Tuesday, Oct 12, 2010 at 19:16
Just to add that Mitsubishi specify weight limits on each axle - 1800kg at the rear and 1260kg at the front.
If you overload the vehicle behind the rear axle, you will increase the rear axle weight even more and lighten the front. The heavy duty suspension and airbags stop you from seeing this.
Those airbags on leaf sprung vehicles are a major issue - they can support huge weight - mine can take over 2000kgs, so all too often they take all the weight, while the leaf springs are left to do nothing. So all the weight is supported in one spot immediately above the axle, rather than on two locations at each end of the leaf.
FollowupID: 703574
Follow Up By: _gmd_pps - Thursday, Oct 14, 2010 at 22:29
Thats exactly what a decent airbag installation does ..
2 airbags each side .. one at each leaf hanger or just inside of it,
but I have not seen many like this .. mine is made like this though,
and of course it is not done for higher load but for endurance under
stress... same with shocks ... have double shocks in the front and they
do not get hot on corrugations as single ones do ..
have fun
gmd
FollowupID: 703843
Follow Up By: Gone Bush (WA) - Friday, Oct 15, 2010 at 00:12
Fantastic photo with the rainbow, Phil G.
FollowupID: 703853
Follow Up By: Member - Phil G (SA) - Friday, Oct 15, 2010 at 07:48
Gday GB,
Yep, storm coming in at Streaky Bay last August
phil
FollowupID: 703876
Reply By: Member - mazcan - Tuesday, Oct 12, 2010 at 17:14
hi
right from day one
i have had personel doubt about the mn triton body length /wheelbase and amount of overhang behind the rear axle ever since it came on the market especially since they made the longer body option availuble without extending the wheel base
it looks out of proportion and i have actually been seating back quietly waiting and watching
because i was expecting something of this nature
i chatted about the pros and cons with a mate i've known for 60 odd years
we are both ex farmers and both were of the same opinion that something would happen
we have both seen truck chassis bend through having loads to far back
re above facts and we both said time will be the telling factor
i showed him the article today, cant print what he said but
you guessed it neither of us are surprised
you cant have all that overhang
then add all the extra bits and pieces 2 spare wheels plus oversize fuel tanks etc and then the down thrust off a trailer on a towbar even further back to give the g-forces an extra boost
it's a sure thing that the g-forces were going to have their way at the weakest point
most of the dualcabs imho have very light chassis considering they are 1tonne load rated
and look at that large side hole in the chassis rail in the small picture right where it bent that would be a major flaw in the chassis design thats where the chassis should have been beafed up and you wait and watch the next model will get something to that nature done to it
but they they probably wont tell us
just my thoughts on this devastating event for all the unfortunate owners out
there
i wish them all luck in the battle with mmal
there's a lot more to a good tug vehicle than just having a big gutsie
engine
AnswerID: 432806
Reply By: splits - Tuesday, Oct 12, 2010 at 19:55
I think a point that often gets overlooked with dual cabs is how much weight is in the cabin. If you have a 75kg man and a 60kg woman in the front plus a pocket size child in the back seat then pile loads of weight into the rear while carefully keeping the car just below GVM, you might have a few problems.
On the other hand, put four rugby forwards in the cabin, a couple of hundred kilos of gear in the back and about 100 on the tow ball and you could most likely drive around for years on stock suspension without a worry in the world
until the car eventually dies of old age.
Correct weight distribution seems to be the critical factor with these things.
AnswerID: 432820
Reply By: Member - Ted - Tuesday, Oct 12, 2010 at 22:02
Mate, sorry to hear about this. Wish you all the best. Please keep us updated with the progress. Cheers - Ted
AnswerID: 432835
