AnswerID: 2315 Submitted: Thursday, Mar 07, 2002 at 00:00
coghead
replied:
Hi Mike, your advice from your friend is generally true, a gearbox is in effect a torque multiplier, by that I mean, that in 4th gear of most manual gearboxes, it is 1:1 ratio, meaning that available engine torgue at the flywheel goes straight thru the gearbox to the transfer case/tailshaft/diff/s. Think of the gearbox as having an input shaft (front) and a output shaft (rear), and the 5 gears allow a change in speeds between the input and output shafts, except 4th gear which is usually 1:1. When you go down thru the gears, the gearing change in effect multiplies the engine torgue, ie more engine crankshaft revolutions for given tailshaft revolutions, the input shaft is spinning faster than the output shaft, so in effect more energy is delivered to the output shaft, as you go down the gears. However, with 5th gear, it is an overdrive, the input shaft is spinning less than the output shaft, so is reducing the available torgue to the tailshaft.This is fine when cruising with a light/ medium engine load, and the engine producing near maximum torgue, which is generally from 2,000 to 3,000 rpm, depending on engine type, petrol/diesel, and design. In 5th gear, because of the overgearing, there is an energy loss, and low speeds in 5th gear, generally labour the engine, and allow excess torgue loss in the gearbox.
Ever see the old bloke chugging along the highway in a diesel 4wd, with a van or trailer at 60-80 km an hour with smoke billowing from the exhaust, well, thats him in 5th gear, labouring away. Would be more efficient and friendly to his vehicle in 4th gear, where the engine would generate sufficient torgue to allow a light throttle, and not have the high torgue load/loss happening as the power transferred thru the overdrive gearing in his gearbox.
In a nutshell, if the load is light, no trailer etc, flat terrain, 60-80 km/h is generally not a problem in 5th gear, but I doubt that any big efficiencies are gained. Hopefully others may have some input too, cheers.
Reply 1 of 6
