Not another diff locker question
Submitted: Friday, Oct 31, 2003 at 22:30
squiz
Can a LSD be put on the front of a GU Patrol?
Reply By: Mick - Saturday, Nov 01, 2003 at 19:57
No.
But i used an old MK LSD in my old GQ, but had to machine the PCD of the crown wheel bolt holes out further so it fitted.
The inner splines were the same in the mq-mk rear as the front of the GQ, which should be the same in the 4.2 front gu diffs.
It worked excellent and cost me nothing, as i did it all myself, and was very proud, as was then the only one around!
35913
Follow Up By: squiz - Saturday, Nov 01, 2003 at 21:12
Thanks for the input Mick
I may try finding a good 4X4
shop
or wrecker to see if they would take the
project on.
25927
Reply By: Red Rover - Sunday, Nov 02, 2003 at 09:09
I used a pathfinder rear and bolted straight in to the GQ ring gear- no machining. The only thing u have to do is remove the centre block.
Hope it Helps
Red Rover
35945
