Aussie Camp Shower
Submitted: Saturday, Nov 01, 2003 at 20:53
G'day, I was wondering if anyone uses this www.aussiecampshower.com , I found it on the net and wanted to know how it handles cold wheather. I liked the idea of not being attached to your car for a shower when you consider it is around the same price at $423 as the twine or glind showers. Thanks for any help.
Tassiedave
Reply By: Phil G - Saturday, Nov 01, 2003 at 21:32
I had an underbonnet shower, and used it for a couple of years, but I doubt that they are worth the money. I find it much easier to heat up the billy on the fire, add it to some
water in the 10 litre bucket and use a $25 electric shower. The
water temp's perfect and constant every time.
35920
Reply By: Member - Bradley- Saturday, Nov 01, 2003 at 21:41
Hey Dave, i have had a good look at these and they look ok, but they are fairly large with light weight tube for the shower head, the heat exchanger looks like it would grab all of the heat from the burner but they would take up a bit of space, saw a new unit from Primus the other day that is basically a small toolbox with the heat exchanger / burner in one end and a Jaycar style 12v shower pump in the other end, it would be a lot tougher and probably easier to pack. But you still need to cart around a gas bottle.. But i understand if you are from Tassie, then you will need a good hot shower, as it is bleep efull cold in Melb still, so i assume you guys are not much better !! I've got to come to Tas for a week for work soon but i am holding off until the weather improves :-) Cheers BradLife is short- but there's always time for a yarda.
35922
Follow Up By: Shaker - Sunday, Nov 02, 2003 at 14:16
The Primus unit only raises the ambient
water temperature by 18 degrees
25960
Reply By: Phil P - Sunday, Nov 02, 2003 at 07:24
Hi Dave,
I saw these being demostrated at the Wandin 4wd show, they work
well but are quite large to carry. I ended up buying and installing the Helton Unit.
http://www.helton.com.au/
All up it cost me $180.
What I do is use it to heat up a large bucket of
water & then use the turbo shower from the bucket of
water that has been heated up. That way I am showering away from the car.
Phil P
35942
Reply By: chopper - Sunday, Nov 02, 2003 at 08:33
Dave, I actually have one of these!!
I have found that while it consumes a fair bit of space (incl gas bottle) it pumps out a serious amount of very hot
water.
We went this way because we needed the ability to produce large quantities of hot
water quickly (like 50 peoples worth)
As a shower, the
water coming out is too hot for many people,
We mostly use ours to provide hot
water for washing dishes (big group) and have the ability to provide hot showers should we need to.
As a side note, one of the students was getting
water for wash up and he accidently stepped on the power cable for the little pump, this pulled it ever so slightly out of its socket and the pump turned off. Due to the noise that the burner makes (that's a whole hell of a lot of noise BTW) he did not notice until the unit had already run dry. So at the moment I have a very schmick looking blue tube with mangled, twisted and broken copper pipe running thru the middle of it, not happy.
If I had my time again, I would still have bought this unit for my purposes, however if i only needed to provide hot
water to a family, i would probably just get the $20 shower sets and organise my hot
water on the stove, much less mucking around, much less gear to cart.
that's my 2c
35944
Follow Up By: Shaker - Sunday, Nov 02, 2003 at 14:17
I thought that you could adjust the gas supply valve on the unit itself to regulate the
water temperature, by reducing the gas flow.
25961
Follow Up By: chopper - Sunday, Nov 02, 2003 at 14:54
you can, but it does not make a very big difference to the tempurature of the
water in the end.
25962
