Anderson plug from alternator
Hi all
Just wondering if someone could tell if it is ok to run an anderson plug for the camper trailer straight from the alternator. I have a D40 navara if that makes a difference.
Thanks in advance
Duncan
Reply By: ChrisK - Friday, Nov 19, 2010 at 08:21
Duncan,
The best bet is to runthe wires through from your existing battery but also include a "redarc" controller in between them to control the current flow & draw. Here is a link to a we sit that show a really good way of doing it:-
Dual battery wiring link
I did it this way to connece the batteries in my van to charge of our Jeep. It also looks after the aux battery in the back of the vehicle. Hope this helps.
ChrisK
AnswerID: 436339
Follow Up By: Ray - Friday, Nov 19, 2010 at 19:32
I've never used a Redarc just circuit breaker
FollowupID: 707667
Reply By: ABR - SIDEWINDER - Friday, Nov 19, 2010 at 08:27
Here is a picture that may help you.
Derek from ABR
AnswerID: 436340
Follow Up By: PradOz - Saturday, Nov 20, 2010 at 10:17
HI Derek
Can you please post up a picture of yours that i have seen before and cant locate now showing following set up:
Main starter in car, aux 1 in car, aux 2 in van.
also need to know position and size of fuses etc that maybe needed. I was told by a "battery specialist" last week that fuses were optional between the batteries, he said i can connect directly between battery and isolator with no fuses - is that actually correct??
trying to set mine up now in my "new" 120 i just got and need to know does it matter where i put the isolator in car between starter and aux 1? (does it have to be near one battery rather than the other?)
then what do i put between aux 2 in van and aux 1 in car to separate them, or is it necessary, can i just connect batteries together via cables + ando plugs?
Not sure what isolator i will use at moment - redarc or other, not sure yet. had H/duty solenoid in last prado. "Battery specialist" was pushing a MATSON
I was also thinking about connecting up a battery volt meter i got from you for my last car and a optional start connection in the car on the dash. I have seen a photo of your new volt meter fitted in your 150 (which looks smaller than mine) that allows you to check either battery and connect them for jump start too i think from memory - what size is the unit and what price is it please
thanks Derek, i remember your diagrams being very simple to understand and your advice and service is always excellent. MANY THANKS MICK
FollowupID: 707722
Follow Up By: ABR - SIDEWINDER - Saturday, Nov 20, 2010 at 11:00
Hi Mick
Here is how the isolator is connected, fuses must be used if the batteries are not very close to each other or there is any chance of the wiring being damaged in any way. Note: If you plan to use the jump start feature you can't fit fuses. This applies to batteries under the bonnet and close to each other, all other batteries and wiring MUST be fused.
Contact me for more info, drawings and specs.
Note: We no longer support Redarc or their products, we have been asked by Redarc not to sell their products.
Derek from ABR
FollowupID: 707727
Follow Up By: PradOz - Saturday, Nov 20, 2010 at 12:15
Thanks Derek , hey are the exact pictures I had seen before and was looking for.
Couple more questions if I could just clarify please. Happy for you to reply direct to my email if easier (v8footy AT hotmail DOT com)
Q1 - Please clarify something that is different between both sketches. Sketch one shows Car Aux Negative connected to Chassis. Sketch 2 shows Car Aux and Car Starter Negatives linked directly together. Which way is the better in your opinion?
Q2 - You say to eliminate the fuses if I use an over-ride switch/function. Is that both of the fuses shown each side of the Isolator between the Car Starter and the Car Aux Batteries shown in your second drawing? If so, I keep the fuse to the Van Aux Battery even with over-ride? Also I am putting Car Aux on drivers side behind headlight - is that distance of cable ok if not fused because I am using the over-ride?
Q3 - Price please for your ABR isolator (to postcode 2560 if you need to know it)
Q4 - Price please also for your ABR over-ride switch/voltmeter as pictured on your dash. (it does both volt readings for both batteries and also connection for jump start??) Please also supply price for fuse(s) if they are needed after reading my Q2 above. I would rather get everything at once from you i think. I should have enough cable already, if not will let you know later.
Q5 - What are the physical dimensions of your pictured over-ride switch voltmeter?
Q6 - Its interesting looking at your 2nd diagram. Everyone here has told me I cannot connect both the Aux Car Battery and the Van Aux Battery to the same isolator. I was told to connect an isolator only between Car Starter and Car Aux, then connect the Car Aux separately to Van Aux by separate cable/anderson plugs. I like your way best as it was what I was asking others about. Will it only work with your isolator that way. Is there any reason to not do it your way and to run separately as others have told me? Does it effect any connections if I use your pictured dash over-ride switch voltmeter (other than fuses as you mentioned and my questions above on fuses)
Lastly, Q7 - do you have a 12" battery tray that fits the 120 series prado petrol to go behind drivers headlight and if so does it have support for power steering fluid resovoir. If you do, could you pass on the price of that too please. (I have seen your tray for the 150 series but not sure if you have one for the 120 and it to also suit petrol)
Many thanks for your time again, cheers Mick
PS - Sorry about so many Qs, just want to get it right and only do it once. The Minister for Finance here is not so happy me spending $ on the car and van when I am off work with no income at all due to spinal surgery for a back injury. Sure i will get over her "advice" in the long run - Just as long as I only spend once for what i do i should be ok (I hope) - cheers mick
FollowupID: 707732
Follow Up By: PradOz - Saturday, Nov 20, 2010 at 13:49
Derek - i have found your web site again (having the internet go back up to speed here now certainly helps) so please disregard Q3, 4, 5, 7 as i think i have the info from there.
But if you have time I am unsure about Q 1, 2, 6 in my reply above
Thanks again mick
FollowupID: 707743
Follow Up By: ABR - SIDEWINDER - Saturday, Nov 20, 2010 at 14:30
Hi Mick
I will email you so we do not hi-jack this thread or start a war.
Derek
FollowupID: 707757
Reply By: Member - Serendipity(WA) - Friday, Nov 19, 2010 at 09:06
Hi Duncan
Both the previous answers are the correct way to run your wiring.
I think you are asking can you run a second wire straight from you alternator to a second battery in the camper.Well no. I mean you could but the effect would be to divide the available current from your alternator between two sources and the second source would drain a lot more with the distance of the wire.
The result would be neither battery would be charged up and you could overload your alternator as it constantly tries to pump max current to both sources.
You could set up a second alternator if you have room under the bonnet to charge the camper. But the best is to run it like the others have shown. If you are having problems with the current drop on the camper battery charging add in a DC to DC charger. These will pump up the charge getting to the second battery.
David
AnswerID: 436343
Follow Up By: Nomadic Navara - Friday, Nov 19, 2010 at 14:34
I cant get what you are on about. The cable from the alternator to the battery has so little resistance in it that it does not matter which end of the cable he connects to.
Duncan did not say if the connection was to charge a battery or just power the things in his camper. If it is the latter he will not want an isolator in the line. As he is running the cable to a trailer he may just want to disconnect the trailer to protect the starting battery each night if he has a battery in the camper.
If he is going to use an isolator it really does not matter electrically which end of the alternator to battery cable he connects the isolator to.
FollowupID: 707651
Reply By: Nomadic Navara - Friday, Nov 19, 2010 at 14:23
The first question to ask is why the alternator and not at the battery?
I have just looked at my D40. The connection from the alternator to the battery looks a good solid one. I don't think there would be advantage voltage wise by taking your feed from the alternator.
The terminal on the alternator is not as easy to get to as the battery terminals. When you connect to there you will have disturbed the alternator connection which may have warranty considerations. It will not be in view so you can check it when doing your quick under bonnet inspections. When the motor rocks as part of its operation there will be flexing of your cable. If you are not careful with your connecting cable it may fracture, there will be less flexing if you connect it to your battery. You will have to make extra care to insulate your terminal in case the mechanics short it out during regular routine maintenance. They will be careful around the battery but not expect uninsulated conductors elsewhere.
With all these practical considerations and no voltage advantage I ask again, why at the alternator instead of the battery.
AnswerID: 436361
Follow Up By: Mike DiD - Sunday, Nov 21, 2010 at 19:24
Maybe he thinks that if he connects it to the Alternator, then when the engine is off, if he discharges the Trailer battery, it won't discharge the Main battery, saving the cost of an Isolator.
No, it's not practical to access the Alternator before the diodes. There's a very permanent connection between Alternator and Main Battery - that's why everybody goes to the expense and hassle of putting in an Isolator.
FollowupID: 707897
Follow Up By: Member - Phil G (SA) - Monday, Nov 22, 2010 at 11:30
I think the main issue is that you can blow the fusible link between alternator and battery which is normally rated according to the output of the alternator.
With an anderson plug connected to the alternator, you are hooking up an auxillary battery on the wrong side of this fusible link. It becomes possible then to overload this fusible link during heavy loads such as cranking, or when the preheat circuit is active or winching because you can easily draw additional current from the auxillary battery.
FollowupID: 707965
