Terrano 2 Brake Controller.
Submitted: Sunday, Nov 02, 2003 at 14:22
ThreadID: 8257 Views:1690 Replies:3 FollowUps:2
Where do you install a Tekonsha brake controller in a Terrano 2? I believe that they must not be more than 70 degrees from horizontal. As the dash is almost vertical, & under the dash is way too low it makes it very hard. Only idea That I can come up with is maybe in the ashtray opening.
Reply By: hoyks - Sunday, Nov 02, 2003 at 20:07
How about in the storage bin under the ash tray, in front of the gear stick. If you grab the sides of it you can pull it out and maybe modify (cut it) to fit the controler, or make up a bracket to fit.
AnswerID: 35979
Follow Up By: Shaker - Monday, Nov 03, 2003 at 11:09
Good idea thank you ... but probably a last resort as one of the Terrano's shortcomings is a lack of storage spots. By the way, could you let me know how you go with fitting the Courier snorkel.
FollowupID: 26000
Reply By: hoyks - Monday, Nov 03, 2003 at 19:43
I get a bull bar on Thursday, so the snorkle is next on the "To Do" list.
AnswerID: 36104
Follow Up By: Shaker - Tuesday, Nov 04, 2003 at 18:44
What bull bar are you fitting? Be keen to see a photo when it's fitted, as I have been looking for one, I can only find fairly light duty ones like the ECB Adventure Tube Bar.
FollowupID: 26095
Reply By: hoyks - Tuesday, Nov 04, 2003 at 20:46
That's the one. Best of a bad lot. It is the only one I could find that is made from tempered alumunium, most others are made from comercial grade that polishes nicely but is soft as butter. It is also $300 cheaper than a replacement bumper, painted and fitted. I hope to fit it Thursday
AnswerID: 36225
