AnswerID: 36173 Submitted: Tuesday, Nov 04, 2003 at 11:25
Aussie03
replied:
The patrol is ultimately better offroad than the pajero, due to its live axel set up both front and rear. However front inderpendent
suspension is not without its advantages, it makes for a better ride on road, and for touring it is certainly alot more forgiving than live axel. The right
suspension lift for independent will compensate for limited travel. If your really keen you could remove the anti sway bar and squeeze a few more centremetres of travel out off the front
suspension, just don't tackle corners too fast. Short wheel base 4wds will make better offroaders, as they have better departure, approach, and ramp over angles, the only set back is the limited carrying capacity of these vechicles. You mentioned that you intend to do some serious offroading,
weather you go for the pajero or the patrol you will have to at some stage look at a
suspension lift. It all narrows down to where you spend most for your time driving. More offroad driving then i recommend the patrol. However if your after a good compromise between on and offroad driving the the pajero is the pick of the pack. they offer better onroad performance, while they won't tackle hard terrian with the easy of a patrol they will go as far, and with the right
suspension lift, and diff locks the pajero will confront difficult terrian with the same poise as a patrol. I haven't pesonally driven a 3L pajero, but I have heard they can be short of some leg at times. I would imagine the ecomony would be alot better than the patrol.
Hope this helps, if a bit long.
Reply 4 of 4
