Fly Screens for L300 Van
Submitted: Monday, Nov 03, 2003 at 08:18
ThreadID: 8274 Views:4601 Replies:4 FollowUps:2
I was just after a bit of advice...
At present I am decking out our Mitsubishi L300 4wd van for a trip around Oz.
We were hoping to find a way to put some flyscreens on the windows.
Does anyone know of how we might achieve this, or know of a company who could custom build some for us ?
We are located in Sunbury, Victoria
Many thanks in advance
Reply By: Willem - Monday, Nov 03, 2003 at 12:26
Autopro sell Window Sox for the later model vehicles for around $50 a pair.
We took fibreglass mesh/flywire and stitched them into a cover with a sowing machine to fit over the doors of the Patrol. Cost was about $5 each. You can then wind the window down for fresh air and keep the mozzies out. Too easy!!
Cheers,Willem
Always going somewhere
AnswerID: 36042
Reply By: Member - Royce- Monday, Nov 03, 2003 at 12:55
A few possibilities.... depends on how professional you need to be. Make up correct size pieces of flywire [plastic now] and use velcro stick on thingies. Otherwise... if you want to get a bit more agricultural. Make up standard frames and wire as from a hardware store and tech screw on the outside..... been done before. Removes with a cordless drill easily but leaves little holes that need treating to stop rust.
Anyway mate..... the blowies and mossies up north won't fit through ya windas! So don't worry!Royce www.funshow.com.au
AnswerID: 36046
Reply By: Brian - Monday, Nov 03, 2003 at 13:22
Was at a Home Ideas center on the weekend and saw these
Magnetic Insect screens
Either have them made up or do it yourself easy done, with strip magnets and std fly mesh, will leave no holes in the vehicle!!!!
Hope this helps
Brian
AnswerID: 36055
Reply By: Tony - Tuesday, Nov 04, 2003 at 11:23
Thats what I use, fly screen with magnetic strip sowen into edges, roll up and put inside when you are on the move, stop for the night fit screens on from the outside, open windows, no more bitties etc.
AnswerID: 36165
Follow Up By: AdamMC - Tuesday, Nov 04, 2003 at 20:45
Hi Tony,
Thanks for the tip ;)
Do you sew the magnetic strip inside a hem or sew through the magnetic strip to keep it on the outside ?
FollowupID: 26113
Follow Up By: Tony - Wednesday, Nov 05, 2003 at 07:39
Inside the hem is usually enough so it can still stick to the side of the vehicle, try a bit before you go ahead with it. It worked for me ok.
FollowupID: 26147
