V8 Disco snorkle problems
Submitted: Monday, Nov 10, 2003 at 17:28
Barry B
Hi ya all,
I recently had my local ARB rep fit a snorkle to my '98 V8 Disco.
My immediate problem is getting the rubber hose between the manifold and the air cleaner, to stay on.
When the air cleaner is repositioned, the origional hose was cut down to fit in between, but it keeps falling off.
Has anyone else had the same problem, and if so how did you fix it? Is there an after market replacement hose?
Cheers all,
Barry.
Reply By: diamond(bendigo) - Monday, Nov 10, 2003 at 17:51
gday barry.
first thing i would do is take it back to your local arb guy.
thats the reason we pay them good money so things like this dont happen.
back by popular demand
36754
Reply By: Member - Tim&jan - Monday, Nov 10, 2003 at 18:47
snorkles are fitted because they give you more power and also for driving though
water i wouldnt wont a loose one it could become very expensive take it back it should be sealedgu bush basha
36764
Reply By: Member - Ross - Monday, Nov 10, 2003 at 19:03
Bazza
2 points ...
1. Stick it to the ARB blokes, my guess is they would have charged you 1 arm, 2 legs and the virginity of your maiden aunt (long deceased). Sounds like they cocked up and that's not good enough.
2. If it's
water crossings you're hoping to cater for...don't forget the coil behind the passenger headlight, unless it's been relocated. That's where the gooses put it on my 95/96 model. On overcast sky had you reaching for the WD40.
Best of luck and giv'm heaps.Rosco
36766
Follow Up By: Member - Ross - Monday, Nov 10, 2003 at 19:11
P.S.
The gooses to which I am referring are the original designers...
;-DRosco
26576
