fan viscous couplings
Submitted: Tuesday, Nov 11, 2003 at 13:18
Goran
What is an expert oppinion on a subject of modifying viscous coupling so that it turns all the time. I live in Notrh West and the temperatures here are hi almost always. i am aware of drawbacks in the cooler climates but here seems to make little diference. A lot of station vehicles are modifyed in this manner up here. I am on my third coupling in 2 years now ......what are the options beside fitting electric fan.
Reply By: Tony - Tuesday, Nov 11, 2003 at 13:53
Just use a solid fan like the early crusiers, find one that has the same bolt pattern, and do a swap.
On my old 2H I used a Dyna truck fan and it worked
36840
Reply By: Member - Des Lexik(SA) - Tuesday, Nov 11, 2003 at 14:11
G'day Goran,
long time no hear from you. good to see you still around.ne cede malis
36842
Follow Up By: Goran - Tuesday, Nov 11, 2003 at 14:24
Good to be back mate. Still around and kicking.....:-)
26644
Reply By: howesy - Tuesday, Nov 11, 2003 at 18:45
See if it has screwws around it. if it has , I stripped
mine and washed it out with turps and then dried it, after which I added three vials of genuine Toyota silicone oil at $10 a vial. Toyota recommend two but I find that with two they are borderline. if you add three then it gives that little bit more drive while still allowing slip for river crossings.
Mine runs like a dream temp. wise now.
36888
Follow Up By: SupaMav - Tuesday, Nov 11, 2003 at 19:50
howesy . . . I assume that you have a Toyota. Do you if the Nissan ones are serviceable?
Mine's pretty much siezed.
26681
Follow Up By: howesy - Wednesday, Nov 12, 2003 at 16:53
Dont know buddy. Take a good look at it and if it has some recessed screws around it then it is serviceable. A warning though, I had to get a pair of vice grips on the screw driver to get the screws undone. They are one tight mothers. Figured that was a gentler option than an impact driver. Good luck hope it works for you.
26765
