1997 Y60 Patrol RD28T LWB RX
Submitted: Wednesday, Nov 12, 2003 at 21:41
ThreadID: 8485 Views:2549 Replies:2 FollowUps:5
I have the following problem with my patrol and really appreciate if any body has had a similar problem or knows somebody who might have had this problem.
The car is hard to start when the motor is hot when left for 10 to 20 minutes before restarting. The car starts first kick when cold.
I bough the car second hand not long ago, and have since had the injecters serviced and a full tune, and the injectors were replaced under warranty. It used to start better than it is starting now. The car has 140000km on the clock at the moment. Otherwise the car goes well, with the exception of the above.
There was a posting by Peter (Post ID 6008) with the same problem amongst others, I currently have to do what was suggested, i.e. waiting for ever (it seems) for the glow plugs to warm up.
Any comment would be greatly appreciated.
Thankyou in advance,
Reply By: Eric Experience. - Wednesday, Nov 12, 2003 at 21:54
Luigi.
If you want help to diagnose you problem you will have to give more information, is the motor turning over on the starter ok? when it does start is it blowing black or white smoke? when you say hot do you mean warm or normal operating temp? Eric.
AnswerID: 37081
Follow Up By: luigi - Wednesday, Nov 12, 2003 at 22:31
Sorry about that. Yes the motor turns over on the starter O.K. And depending on how long it takes to eventually kick over The smoke varies from a little bit of greyish smoke to a lot if it takes a long time to start. Yes when it has reached normal operating Temp.
Thanks Eric
FollowupID: 26807
Reply By: Member - Eric- Wednesday, Nov 12, 2003 at 22:22
Dont worry about going any further in diagnisis mate , The problem is your timing pump . Very Very common on the 2.8 , in the morning it will start like a jem , run it for a while and you can crank till your hearts content, Might start if your lucky , with a big puff of smoke ,. sound familiar ? I think the reco cost is between $1500 and $2000 Venus Bay
AnswerID: 37086
Follow Up By: luigi - Wednesday, Nov 12, 2003 at 22:34
I hope its not that. The car is still under an extended warranty, I suppose my problem if this is the case is to convince then and get them to fix it.
FollowupID: 26808
Follow Up By: Member - Eric- Wednesday, Nov 12, 2003 at 22:43
what area are you in ?? I will bet you anything , I had a guy almost rebuild a motor , to find it was the pump , common as sheep in NZ , ask any Nissan dealerVenus Bay
FollowupID: 26809
Follow Up By: Truckster (Vic) - Wednesday, Nov 12, 2003 at 23:45
I'd be happy if it was a $1500 pump over an engine rebuild.
if your in Melbourne goto BJ Diesel.. Clinton there is GOOD.. he will tell you.
if its under extended warranty, you have no problems.. But read the fine print..
FollowupID: 26828
Follow Up By: luigi - Thursday, Nov 13, 2003 at 19:33
Thanks Guys
I'm in sydney, we will see how cooperative the dealer is. I also would prepare to pay for a pump rebuild over an engine rebuild, but seeing its under warranty I rather not pay anything, they get enough out of me from the serviceing.
Thanks again for your help.
FollowupID: 26944
