Transfer case vibration damper on '99 Hilux
Submitted: Friday, Mar 11, 2011 at 19:47
ThreadID: 84930 Views:8110 Replies:1 FollowUps:1
Hi, I've just joined and thought this may help other Hilux owners. The vulcanised section of the vibration damper on the transfer case breaks after a while and Toyota want $440 for the whole part (large lump of steel included). I found a replacement vulcanised part for $132 from Burson Auto Parts. It is a Mackay Rubber part #A5801 and fits exactly. You need to do a bit of grunt work to get the old one out, drilling out 4 spot welds and replacing them with steel rivets but it saves a whack. I've seen that one of the older archived threads on the site had a response to remove the part and throw it away. DO NOT DO THIS unless you intend throwing the vehicle away soon or plan on a major gearbox or transfer case rebuild. The harmonic vibrations will eventually destroy the seals and mountings.
Cheers Grant
Reply By: Member - Scooby (WA) - Saturday, Mar 12, 2011 at 10:01
Thanks for that info Grant. I did wonder what that lump of metal was for and mine has broken away from the vulcanised section. Where is Burson Auto Parts?
Scooby
AnswerID: 447973
Follow Up By: Grant T - Saturday, Mar 12, 2011 at 11:13
Hi Scooby, Bursons seem to be an East Coast company but the part is made by Mackay Rubber and I've just downloaded this from their web page.
Western Australia:
Automotive Products
P.O Box 3089
Shelley
WA 6148
Australia
Telephone +61 8 9457 8609
Facsimile +61 8 9457 3382
I checked and the part comes up easily if you enter the part # A5801.
Hope this helps, cheers. Grant
FollowupID: 720325
