cruise control magnet
Submitted: Monday, Nov 17, 2003 at 22:42
ThreadID: 8590 Views:4722 Replies:7 FollowUps:7
hello all I have a 80 series base diesel and found that the origanal cruise control magnet was missing off the tail shaft . must have knocked it off the last time in the bush .I purchased a new magnet from auto barn, they told me to fit it with fine wire. Well after only a few km,s at highway speed it was gone again . any clues of how to keep them on the tail shaft would be helpful
Reply By: Mike - Monday, Nov 17, 2003 at 23:13
Try using some silicone as well as the wire. Make sure the job is clean and leave it to cure properly before using the vehicle. Ensure that there is sufficient clearance and that the wire is trimmed properly.
AnswerID: 37615
Reply By: Goodsy - Monday, Nov 17, 2003 at 23:42
Having the same problem with my cruise. Have not got around to it yet but going to use wire and arildite to keep the bloody thing on. Have lost one magnet. don't want to loose any more.
AnswerID: 37621
Reply By: Mark - Monday, Nov 17, 2003 at 23:46
I used araldite and some cable ties. Never came off after many years.
AnswerID: 37622
Follow Up By: joc45 - Tuesday, Nov 18, 2003 at 00:57
Ditto. Scraped the paint off the tailshaft, removed the double-sided tape off the magnets (if fitted), araldite the magnets on, then wrapped the wire around, and smeared araldite along the wire so it could not vibrate/fatigue in any way. Never had a problem after that on the old GQ.
Oh, and also checked that the pickup coil was not too close to the magnets - the tailshaft shakes around quite a bit and can knock against the pickup coil, with obvious results. Even araldite won't save the magnets if they hit the pickup. I recall a good cm gap was necessary.
Gerry
FollowupID: 27243
Reply By: Viola - Tuesday, Nov 18, 2003 at 02:22
phone command auto in sydney who are the importers of the command cruise control and they have the magnets in what is like a very strong cable tie all made up for about $10
AnswerID: 37636
Follow Up By: Member - Glenn(VIC) - Tuesday, Nov 18, 2003 at 10:39
Hi Viola,
I had the magnets attached by the cable tie, and it took one stone to snap the cable tie and the magnets eventually vibrated off. The replacement magnets I bought from Command had the wire to secure them to the shaft and this is more secure than the cable tie.
Just my opinion.
CheersJust Do It!
FollowupID: 27271
Follow Up By: Member - Glenn(VIC) - Tuesday, Nov 18, 2003 at 10:51
Hi Viola,
Just my opinion.
CheersJust Do It!
FollowupID: 27273
Follow Up By: Member - Des Lexik(SA) - Wednesday, Nov 19, 2003 at 11:57
Viola or Glenn, can you advise me of a phone number in Sydney or Melbourne for Command. Many Thanks Al ne cede malis
FollowupID: 27402
Follow Up By: Member - Glenn(VIC) - Wednesday, Nov 19, 2003 at 12:13
Hi Des,
I have it at home, I will post tonight
CheersJust Do It!
FollowupID: 27405
Follow Up By: Member - Glenn(VIC) - Wednesday, Nov 19, 2003 at 21:20
Hi Des,
contact number is 02 97140990
or
PO Box 6043
Silverwater
NSW 2128Just Do It!
FollowupID: 27460
Follow Up By: Member - Des Lexik(SA) - Wednesday, Nov 19, 2003 at 22:07
Thanks for the info Glenn.
If you want to touch base off line, my e-addy click on the photo.ne cede malis
FollowupID: 27467
Reply By: Hatcher - Tuesday, Nov 18, 2003 at 10:04
How about using some of that metal/epoxy compound, shouldn't come off then....
AnswerID: 37658
Reply By: Member - DOZER- Tuesday, Nov 18, 2003 at 22:04
Gday
If it is a 9/92 or later cruiser, you can wire into the electronic spedo sensor off the transfer.
Andrewwheredayathinkwer mike?
AnswerID: 37735
Reply By: sundance - Tuesday, Nov 18, 2003 at 22:43
the magnet I used was in a small metal cradel with lugs on both ends to take the wire . I only had about 5mm clearance .sounds like 10mm is the go and some epoxy resin . I spose I should check my gearbox mounts for movement thanks for the replies back to the bush cheers.
AnswerID: 37745
