Body lift GQ patrol
Submitted: Thursday, Nov 20, 2003 at 23:40
ThreadID: 8654 Views:3967 Replies:3 FollowUps:0
G'day all in the middle of doing a body lift and was just wondering if the spacers go on the top of the original body mounts or under or do i take the original ones out.
Cheers paul
Reply By: Truckster (Vic) - Friday, Nov 21, 2003 at 13:05
You should put some rubber between each side.. I left the rubber blocks in there..
But going to pi$$ my body lift off.. Created too many bangs and clunks, + even using Nyloc Nuts they always come loose.
www.gqpatrol.com has a good "HOW TO" on body lifts.
AnswerID: 38018
Reply By: Mick - Saturday, Nov 22, 2003 at 12:31
The rubber blocks will only fit under your blocks.
They have a steel pipe through the chasis part, and then fit into the bottom rubber bit. Youll find out when you remove them.
If you go over 2" youll have to bend your gearstick a bit so it wont hit the dash!
AnswerID: 38099
Reply By: Pauly - Sunday, Nov 23, 2003 at 22:46
Thanx for the help i managed to get it done wasnt that hard at all
Cheers paul
AnswerID: 38227
