Clutches
Submitted: Friday, Nov 21, 2003 at 20:58
ThreadID: 8670 Views:1714 Replies:1 FollowUps:3
Are the clutches the same for a normally aspirated diesel (1 hz) and a turbo diesel or is one for the turbo diesel larger?
Rob
Reply By: Member - DOZER- Saturday, Nov 22, 2003 at 18:13
Gday the t/d clutch is larger by an inch or two.
The centre spline is also different.
Andrewwheredayathinkwer mike?
AnswerID: 38121
Follow Up By: Rojac - Sunday, Nov 23, 2003 at 07:43
Dozer
Would the td clutch fit on the non turbo motor??
Rob
FollowupID: 27683
Follow Up By: Member - DOZER- Sunday, Nov 23, 2003 at 13:47
AFAIK the flywheels are thesame, meaning either clutch will fit. For instance you can put a t/d pressureplate and a custom clutchplate in there.
Seen troupies do this when swapping from 1hz to 1hdt
Also know of a hj105 that has a 1hdft motor in it, but that was motor and box together, 1hz 105's use the Prado 5 speed and bust them easily when turboed.
Andrew wheredayathinkwer mike?
FollowupID: 27699
Follow Up By: Rojac - Sunday, Nov 23, 2003 at 17:48
Dozer
Thanks very much for that.
Rob
FollowupID: 27712
