gu patrol rear left side window
Submitted: Tuesday, Nov 25, 2003 at 04:35
ThreadID: 8733 Views:1893 Replies:1 FollowUps:1
hi all, its good to see some rain falling in sydney i hope more areas are getting some as well especially those that need it. anyway to the question, the rear left side window on a gu patrol having a thin strip circulating thru it but open ended therefore not being a demister i suspect a aerial but the car has a more conventional one anyway so is it nissan factory fitted and not used in australia or something else. cheers rob
Reply By: stillthinkinaboutit - Tuesday, Nov 25, 2003 at 08:03
Hi Ramp,
This wire trace is the Short Wave ( SW ) antenna. My ST was fitted with the Dual Height CD/Cass/AM/FM/SW unit. It uses this for the short wave band.
Regards,
Mark
AnswerID: 38331
Follow Up By: GUPatrol - Tuesday, Nov 25, 2003 at 10:06
It is quite good too, only the series ones were fitted with these radios, although the rear window has the aerial on all models.
The SW is quite good, once stuck in Innamincka with bad weather I was getting weather info from everywhere on the east coast and SA through SW...
Will
FollowupID: 27853
