Tarp over tent - warmer?
Submitted: Monday, Jul 04, 2011 at 10:05
ThreadID: 87368 Views:8449 Replies:11 FollowUps:11
Hi All
Heading off on Wednesday from Perth to do Googs Track, Lake Eyre, a bit of the Simpson (West) and Gt Central Rd back to Perth. Have got everything finally sorted but one thing still worries me. We will be in a 30 second tent and while it has been a great tent over a number of trips, I know it will be very, very cold at night.
Has anyone any experience with throwing a tarp over the top of a tent, and do you think it will help, as in making it a bit warmer inside? Or do you think its not worth the effort, with the extra pegging, roping etc?
We do get some condensation inside most nights (this is without a tarp) but we haven't found that to be too big a problem. We find it usually dries pretty well by the time we get around to packing it up. But do you think a tarp might make that a lot worse?
Reply By: George_M - Monday, Jul 04, 2011 at 10:21
It probably depends on how long you intend to stay at each place, Russell.
It can get windy in Central Australia during Winter (as well as bloody cold!).
If you're only staying over night then it may not be worth the trouble of setting up the tarp. Even if you were staying longer you'd only use the tarp (IMHO) if you needed some extra shade as well.
George_M
Come any closer and I'll rip your throat out!
AnswerID: 459135
Reply By: Fab72 - Monday, Jul 04, 2011 at 12:50
In my experiance...most of the cold comes up from the ground. Insulate yourself against the cold floor of the tent. Rubber camping mattresses and a quilt underneath is the way to go.
Fab.
AnswerID: 459143
Follow Up By: Member - Andrew L (QLD) - Monday, Jul 04, 2011 at 14:11
x 2.. get some substantial insulation between you and the ground.
Nylon tents and air beds are a no-no, except for novices in the desert.
FollowupID: 732706
Follow Up By: Gregh2 - Wednesday, Jul 06, 2011 at 10:30
Layers of newspaper work. You can read the paper, sleep on it, wipe your a..s then light the fire all for $1.20 per paper. Ask any down and out in local parks.
FollowupID: 732855
Reply By: goddosglory - Monday, Jul 04, 2011 at 14:11
i am currently staying in a caravan park in ayr..qld..with a large amount of back packers..most have dome shape tents..80% of them have a tarp over them
AnswerID: 459148
Follow Up By: greydemon - Monday, Jul 04, 2011 at 16:03
But is that for warmth or waterproofing? In my experience cheap lightweight dome tents are 'water resistant' rather than waterproof. I accept that the more expensive ones are ok, but only 20% of backpackers have those - leaving 80% with tarps.
( Apparently 90% of statistics are made up, those above are no exception)
Nick
FollowupID: 732718
Reply By: TTD1 - Monday, Jul 04, 2011 at 17:51
Russell P1,
We have just returned from Lake Eyre using our 30 second tent and yes it was very cold but we used for the first time camp stretchers and thermo rest mattresses. No fly or tarp but we found a gas light very effective to warm the tent and dry the condensation but leave one of the top vents open and you will be fine with a good down sleeping bag,
TTD1
AnswerID: 459178
Follow Up By: Member - Robbo (QLD) - Tuesday, Jul 05, 2011 at 20:06
Were do you get thermorest mattresses?. As has been mentioned airbeds are hopeless as far as keeping warm in the desert but some of the alternatives are very bulky when you are already pressed for space . Are they bulky?
FollowupID: 732826
Follow Up By: Member - Min (NSW) - Friday, Jul 08, 2011 at 22:13
Robbo,
Thermorest is a brand name for a self inflating mattress. When you unroll them they inflate then you blow in a little more air - one breath - and close the seal. There are several other brands and are available at most camping shops. Some are bulkier than others.
Min
FollowupID: 733006
Follow Up By: ross - Friday, Jul 08, 2011 at 22:23
I wouldnt ditch the air mattresses completely. Ive found a good blanket on top of the mattress keeps me warm east of Kalgoorlie on crisp nights.
I wouldnt bother with the tarp over the tent,an extra blanket or a thicker sleeping bag will keep you warm and will have less weight and effort to pack/unpack.
The tarp over the tent does work well in hot weather if the tent is in the sun
FollowupID: 733009
Reply By: Member - Ralph K (WA) - Monday, Jul 04, 2011 at 17:55
Tent's fine as is. Get yourself off the ground i.e. stretchers, and get some insulation. We use jumbo stretchers with self inflating matresses and sleeping bags. Quite often a bit too warm regardless of outside temp.
Rather a bottle in front of me than a frontal lobotomy!
AnswerID: 459180
Reply By: Brian Purdue - Monday, Jul 04, 2011 at 18:49
I used to have zip together sleeping bags with a warmer. She will not come with me any more. Sad really!
AnswerID: 459184
Reply By: AlbyNSW - Monday, Jul 04, 2011 at 21:46
Those 30 second tents are fine, I used one out Lithgow way on the weekend plus did the Simpson with one as well. As others have said insulate yourself from the ground.
The worst thing to use is blow up mattresses as the cold passes straight through them, ditched them after first trip, the self inflating ones with the foam core work fine, have not tried the stretcher bed option though.
AnswerID: 459191
Follow Up By: Member - Dunworkin (WA) - Tuesday, Jul 05, 2011 at 14:04
We use the self inflating mattresses, we also have some sheeting under the tent before we put it up, with our mattresses we use good quality sleeping bags, one over the mattress and the other over top of us, that keeps us very warm in our 30 second tent.
D
Simba, our much missed baby.
FollowupID: 732785
Reply By: Echucan Bob - Tuesday, Jul 05, 2011 at 07:37
The tarp will help if it creates a layer of insulating air around the inner tent cavity. If wind or even a light breeze disrupts the insulating layer it won't keep you warmer. The reason a down sleeping bag works is because the down traps a layer of insulating air around you. I'm not so sure about the concept of cold rising up out of the ground. i reckon the warmth inside the tent (your.body) can be raditaed, conducted or convected away. Some types of bedding facilitate heat loss into the ground- my guess would be that is mostly by conduction.
Maybe a reflective tarp could reduce radiated heat loss (like a 'space' blanket).
AnswerID: 459205
Follow Up By: Echucan Bob - Tuesday, Jul 05, 2011 at 07:40
I wonder if a damp tent also works like a Coolgardie safe? A tarp over the top would reduce such evapourative cooling.
FollowupID: 732759
Reply By: rooster350 - Tuesday, Jul 05, 2011 at 09:02
A few sheets of old newspaper under the mattress make a big difference to the warmth of a bed....stops the cold from coming up
AnswerID: 459210
Follow Up By: Echucan Bob - Tuesday, Jul 05, 2011 at 10:42
Or is the heat going down?
FollowupID: 732770
Follow Up By: Fatso - Wednesday, Jul 06, 2011 at 23:20
Energy travels from high to low.
Hot towards cold.
To make something cold you remove energy.
FollowupID: 732898
Reply By: Member - Des Lexic - Tuesday, Jul 05, 2011 at 17:26
Try and get a piece of Air-cell insulation. It's only about 1cm thick and will roll up like a mat. It has a R2.5 rating and provides an insulating barrier between your mattress and the ground. I have it permanantly in the swag and it does work a treat, not that the swag gets a lot of use nowadays.
On the Tvan, we have a piece of Tourneau cover material made to fit over the canvas roof. Apart from keeping the cocky crap off the roof, it does keep the frost off as well. It just zips onto the lift up lid. The material can be hosed clean very easily.
AnswerID: 459247
Reply By: Russell P1 - Tuesday, Jul 05, 2011 at 17:44
Thanks all for the replies and advice. As far as mattresses go, we have always used an air bed and have generally had no problem with that, by sleeping ON a doubled up quilt, in thermals, with a quilt and blanket over the top. Always been warm enough. But I think this trip will be one of the colder ones.
But this time around, I got sick of supposedly brand new air mattresses leaking straight out of the bag. Returned two and spat the dummy. Bought a self inflating mat, 100mm thick and I think I will be converted very quickly. They are a lot more comfortable than I thought, and this is before it has fully and properly expanded (needs a few days use apparently to reach full potential)
As for the tarp idea, well I have a small one, roughly same size as the roof tent. I will try it out anyway and let you know how it works. It can't make it any colder, thats for certain anyway...
So for good or bad, we are off tomorrow morning for a long squirt to Caiguna, then a shorter one to Ceduna, then we can relax and take it nice and easy up the Googs Track and beyond.
I think my favourite toy this trip will be my new cordless 18v chain saw....
Cheers and cheerio.
AnswerID: 459251
Follow Up By: Member - wadams - Tuesday, Jul 05, 2011 at 22:26
no chainsaws are allowed on googs track
FollowupID: 732838
