Pajero oil pressure gauage issues
Submitted: Tuesday, Jul 05, 2011 at 12:04
ThreadID: 87386 Views:2334 Replies:3 FollowUps:2
Hey guys,
I have trawled the threads but can't find anything related to this issue. I recently had the engine out on my 98' Pajero (petrol), and after it went back in, everything is running fine but my oil pressure guage is going stright to max and staying there, even when key is on but engine is off...... any ideas/suggestions would be greatly appreciated.....
Reply By: OREJAP - Tuesday, Jul 05, 2011 at 12:45
Try the pajero club of Victoria web site. Every model is covered & there is a public forum you can view. Good luck
AnswerID: 459224
Follow Up By: howard_moon - Tuesday, Jul 05, 2011 at 13:04
Thanks Orejap, i had a look at the pajero club website and searched the forum but no luck...i will post there as well.
FollowupID: 732779
Reply By: fisho64 - Tuesday, Jul 05, 2011 at 13:29
try unplugging the oil pressure sender with key on. If it falls back to zero the sender is faulty, if it stays up there is a wire fault somewhere. This isnt Pajero specific but most if not all electric gauges work the same.
AnswerID: 459227
Reply By: member - mazcan - Tuesday, Jul 05, 2011 at 13:47
hi howard
sounds like you may have shorted out the sender wire during the engine job check to see its not damaged enroute somewhere under the bonnet
barry
AnswerID: 459230
Follow Up By: Lex M (Brisbane) - Tuesday, Jul 05, 2011 at 14:02
I agree. The sender connection is either shorted to ground or disconnected.
Some gauges go up when disconnected, some go down and the reverse when shorted.
FollowupID: 732784
