Bep water tank monitor
Submitted: Monday, Jul 11, 2011 at 18:28
Scotty
I just purchased a 2nd hand Windsor Rapid 442 which has 2
water tanks with a Bep marine
water level monitor which has JUST stopped working. I have checked and have 12v DC to the monitor. Has anyone any ideas on how to test and if they have had any problems with the monitor.
much appreciated.
Reply By: The Original JohnR (Vic) - Monday, Jul 11, 2011 at 22:27
I just can't rely on
mine anyway
459701
Follow Up By: Scotty - Monday, Jul 11, 2011 at 22:55
Thanks for the advice and great technical response, did you think of it for long or just want to see yourself in print?
733312
Follow Up By: The Original JohnR (Vic) - Monday, Jul 11, 2011 at 23:13
I have never got into the technical side of the BEP meter, except to try to tune it, I could still never rely on it. Perhaps your battery has gone flat.
I still can't rely on my BEP gauges and I know others share the same opinion.
Scotty, your sarcastic comments are you normally? Charming
733314
Follow Up By: Member - Bruce C (NSW) - Tuesday, Jul 12, 2011 at 06:16
No John, I would say that Scotty is merely looking for some good advice with a bit of background to it.
You know what it is like John, you want some info on one thing or another and some one says "wouldn't touch those things with a barge pole" and it turns out that they are talking through their hat.
In your case you have good background knowledge but you needed coaxing to get to it. Good info and good job.
Cheers, Bruce.
| At home and at ease on a track that I know not and
restless and lost on a track that I know. HL.Lifetime Member My Profile Send Message |
733318
Follow Up By: Scotty - Tuesday, Jul 12, 2011 at 06:45
No John, I clearly stated on my post that I have 12v dc at the monitor, so therefore the battery is NOT flat! and NO I am in NO way sarcastic....
733319
Follow Up By: The Original JohnR (Vic) - Tuesday, Jul 12, 2011 at 07:18
Yours must be different to others that actually have a separate battery source in the back. They require 8-30 volts and usually have a little dry cell battery in the back. They are regarded as unreliable by some other manufacturers. You were sarcastic Scotty.
733320
