cruise control
Submitted: Wednesday, Jul 20, 2011 at 20:40
ozzie4x4
gday
I have a 94 80 series landcruiser (GXL petrol), and I have 2 questions, first one, if the speed sensors are working but the speedo is not, should the cruise control still work. second question, what else could be at fault if the speedo is not working, tacho and other instuments are working,
Thank you
Reply By: 120scruiser (NSW) - Wednesday, Jul 20, 2011 at 20:55
Its the speedo sensor on the gearbox.
Common problem.
You can get after market ones for it. I think
mine was about $140 a few years back. The genuine one is just under $400 from memory.
460452
Follow Up By: ozzie4x4 - Thursday, Jul 21, 2011 at 14:47
$450.00 if you can get one that is here in WA, but I tested it and it works
734173
Reply By: Member - Bucky - Thursday, Jul 21, 2011 at 03:19
ozzie4x4
I have fitted 6 or 7 cruise controls in recent years, and your cruise control should work, if the the speedo is broken.
I could be wrong , but my understanding od cruise control, is they are a tacho, that will hold revs, by opening the throtle to hold the selected revs. The mear fact that you are doing a certain speed is secondary to the theory of it all.
With modern vehicles, it is computer controlled, but with your 80 series, it is manual actuating.
Not sure about the spedo bit, but if you know speeds vs revs, then you have no problems
Bucky
460473
Follow Up By: dbish - Thursday, Jul 21, 2011 at 09:04
Cruise controls all work of speedo sender unit.
734153
Follow Up By: Member - Bucky - Friday, Jul 22, 2011 at 05:28
Sorry Mate
That is not correct.
The manually activated ones I have installed all work from magnets, and a tailshaft or driveshaft sensor. and have nothing to do with speedo sensor units.
Bucky
734258
Follow Up By: dbish - Friday, Jul 22, 2011 at 09:02
Early aftermarket cruise controls used magnets on the drive shafts. Later model aftermarket can be taped ito the vehicle speed sensor, fitted lots to Ford Couriers. Factory fitted always use vehicle speedo sensor.
734271
Reply By: olcoolone - Thursday, Jul 21, 2011 at 09:59
No all cruse controls work off the speedo sender unit but on the 80 series it does pick up a feed from the speed sensor on factory systems or later electronic systems.
I would say if your speedo isn't working then the sender may be faulty or check ALL (under bonnet and inside) fuses to see if there is power on both sides.
If you have an email address or fax I can send you the information when I get back at our workshop.
460484
Follow Up By: ozzie4x4 - Thursday, Jul 21, 2011 at 14:45
thankyou for the replies,
the sensors do work I have tested them, even borrowed the one out of my sons 80 to try ( if it worked was not gonna give it back lol),
olcoolone thanks my email is ozzie4x4@dodo.com.au, I think you may have the answer there a power issue.
734172
Follow Up By: olcoolone - Thursday, Jul 21, 2011 at 16:37
Sent this arvo.
734191
Follow Up By: ozzie4x4 - Thursday, Jul 21, 2011 at 17:35
thankyou I have it
734203
Reply By: ozzie4x4 - Friday, Jul 22, 2011 at 12:00
ok tested the cruise control it is working, tested the speed sensors they are working. could it now be just a simple speedometer guage that is the problem, and will that prevent the cruise control from setting.
thanks for all the replies
460597
