truckster any ideas
Submitted: Wednesday, Nov 26, 2003 at 20:57
ThreadID: 8780 Views:2402 Replies:4 FollowUps:6
my gq has bleep fuel economy before and after fitting my turbo, 2 3/4 exhaust all the way though had it dynoed at 68 killowats??? set fuel mixture still no better
lucky to get 550 ks outa a tank if you look at fuel stats on this forum i should be getting 650+ cant work out why { o i have no fuel leaks ..}
Reply By: Truckster (Vic) - Wednesday, Nov 26, 2003 at 21:50
Mine is the same. TB's is the same after we fitted his Turbo, actually his is worse than before.
I put it down to you have more power now and use it more... phukt aint it..
I had my pump and injectors done thinking that would help....
AnswerID: 38605
Follow Up By: REX - Wednesday, Nov 26, 2003 at 22:00
had my injectors done they said fuel pump was ok
do you know how many killowats yours is putting out for a comparison mines around 65 kwts at 8 pounds boost motor don 300k so dont want to push it also just fitted an oil cooler makes a huge differance to my overall engine temp
FollowupID: 28597
Follow Up By: Truckster (Vic) - Wednesday, Nov 26, 2003 at 22:09
yea not sure, will get dyno'ed one day...
Embarrassing to say that many kw with a turbo!
FollowupID: 28598
Follow Up By: Truckster (Vic) - Thursday, Nov 27, 2003 at 14:33
The good thing Rex, is you can laugh at all those tossers in Yota gettin rebuilds at 400,000 while the GQ is good for 600,000+ easy!
FollowupID: 28638
Follow Up By: Tony - Friday, Nov 28, 2003 at 08:33
Truckster Truckster Truckster Truckster, here you are leading with your lip again, I've had a Toyota with well over 400,000 on it and the motor was never touched, since sold has done another 40,000 and still going strong 4.2 Deisel.
I now have a 4.2T GU and hope to get simular k's out of the motor (if I keep it that long) as for fuel get as low as 10lt per100, average on a trip 12 per 100, and pushed get 14.5.
FollowupID: 82633
Follow Up By: Truckster (Vic) - Saturday, Nov 29, 2003 at 10:26
Tony.. Is 400,000 = to 600,000?
FollowupID: 82717
Reply By: Member - Ken - Wednesday, Nov 26, 2003 at 23:00
Rex
I've posted this before and don't mind doing it again if it makes you sleep any easier.
I turbo'd a 1HZ troopy approx 2 years ago which weighs 3.5t when fully loaded.
The conversion included pump, aneroid and injectors. No Dyno.
Fuel Consumption prior to conversion was:
0 -100Kph 12.5 Litres per 100kms
100 - 120kph 13.5 Litres per 100 kms
Post conversion:
0 -100Kph 13.5 Litres per 100kms
100 - 120kph 15.5 Litres per 100 kms
I then had a mandrel bend, straight exhaust fitted.
Did dick all either way on the fuel consumption, however it almost eliminated the turbo lag entirely which is great.
I agree with 'truckster' that its most probably how you apply the 'pedal to the metal' , or more likely whether your tongue is pointing up or down, who knows - its all a mystery.
As to the Kilowatt thing, weeeeeeeeeeeeell thats better left up to someone of Trucksters profile to comment on.
Ken Robinson
AnswerID: 38624
Follow Up By: Member - Ken - Wednesday, Nov 26, 2003 at 23:03
That should read:
I then had a mandrel bend, straight through exhaust fitted.
FollowupID: 28606
Reply By: Brian- Thursday, Nov 27, 2003 at 00:17
Hi Rex,
I promote the Bi-tron products. I've very good fuel results on many similar type vehicles. You should e-mail me directly. brian@brianrogers.net
Regards,
Brian Rogers. Exploroz 525
AnswerID: 38637
Reply By: bruce.h (WA) - Thursday, Nov 27, 2003 at 14:23
Rex
welcome to nissan driving
AnswerID: 38670
