Landcruiser 100 Series Wheel Not Torque
Submitted: Monday, Aug 01, 2011 at 11:26
Michael G6
I have a 1999 Landcruiser 100 Series fitted with Dealer Supplied Alloy
Wheels.
The
wheels are ROH and have steel tapered seats to use the original steel rim nuts.
Question No1
Are the
wheels meant to have the steel rim nuts?
Question No2
What is the recommenced torque for this set-up as I believe that the torque for the steel rums is 154 ft/ lbs and the alloy 96 ft/lbs.
Question No3
Is the 96 ft/lbs meant for the all alloy wheel that uses the larger nut with the washer?
Any info would be appreciated as I have just had to replace 3 rear wheel studs damaged by a
well know tyre supplier.
Regards,
Michael G6
Reply By: Michael G6 - Monday, Aug 01, 2011 at 11:36
Obviously meant to read Landcruiser 100 Series Wheel Nut Torque (sorry about that)
461483
Reply By: snoopyone - Monday, Aug 01, 2011 at 11:52
It gives the settings in the handbook and i would think that it would apply to all Alloy
wheels as excessive pressure could perhaps cause cracking.
Steel rums would cause sore throats I guess LOL
461486
Follow Up By: Michael G6 - Monday, Aug 01, 2011 at 12:47
Thanks for that.
I gues that's the problem using spell check if it is actually a word it does not correct it.
735153
Reply By: Member - Phil G (SA) - Monday, Aug 01, 2011 at 17:14
Gday Michael,
Those ROH
wheels were the most common 105series mags and were called "Royale".
They take the same standard tapered wheel nuts as the steel
wheels.
97 ft-lb is the correct figure for alloys with the tapered nuts.
Sounds like you need a new tyre supplier :-(
461521
Follow Up By: Michael G6 - Monday, Aug 01, 2011 at 19:21
Thanks Phil. I found out that alloy
wheels were torqued to 96.6 ft/lbs but did not know whether it applied to the units that use the steel wheel nuts as
As for the tyre supplier it is a
well known one but I could not prove that the
wheels had not been removed and replaced by others since they worked on it, although I knew it had not been.
Regards,
Michael
735214
Reply By: Mick O - Monday, Aug 01, 2011 at 18:04
Michael,
this may be of interest to you.
Replacing Toyota wheel studs with high tensile units
Cheers Mick
461531
Follow Up By: Michael G6 - Monday, Aug 01, 2011 at 19:43
An interesting read Mick and would certainly have merit to anyone using their vehicle at the more extreme end of it's capabilities. As for me the standard studs would most likely last me forever provided I keep the vehicle away from incompetent tyre fitters.
Thanks again
Michael G6
735216
