Use Hi Lift Jack on HZJ-105
Submitted: Monday, Aug 01, 2011 at 18:34
ThreadID: 87922 Views:4331 Replies:5 FollowUps:7
Hi all,
first of all a short introduction
My name is Chris and I live in Belgium. Currently swapping the old (t)rusted HJ-61 for a 2003 HZJ-105.
Vehicle is mostly used for travelling and daily driver in winter.
I used to use a Hi Lift Jack on my HJ-61, but since the HZJ-105 has a standard front bumper I'm wondering if it is possible to use the Hi Lift on it.
Changing bumpers is not an option as we are not allowed to do this in Belgium.
Any thoughts ?
Kind regards,
Chris
Reply By: get outmore - Monday, Aug 01, 2011 at 23:18
definitly - get a hublifter - lifting off a bumper jacking point is only marginally better than a waste of time - would have been ok with your 60 with about 15cm of upwards suspension travel by a 100 will pretty much use up the whole jack just to even lift the wheel let along get decent elevation
AnswerID: 461559
Reply By: ross - Monday, Aug 01, 2011 at 23:19
The jack will dent the bottom of the bumper,it will also dent the heavy duty steel bull bars (mine did anyway).
You could try using a piece of timber to spread the load on the bumper.
There is a range of options on google images.
Maybe the webbing with hooks might do the job for occasional use
Site LinkHi Chris
AnswerID: 461560
Reply By: Member Al (Sunshine Coast) - Monday, Aug 01, 2011 at 23:44
The 'Hub Lifter' or 'webbing with two hooks' can be useful to lift a wheel out of a rut or washout (but not for changing a wheel obviously). However when used to hook under a bumper the added length of the webbing limits the height of the lift.
AnswerID: 461563
Follow Up By: get outmore - Tuesday, Aug 02, 2011 at 02:26
hi lifts should never be used for changing wheels - beginners mistake
ive changed wheels everywere rom underground declines to the middle of nowhere exploration non tracks with a factory tojo jack
no webbing about a hub lifter - they do just that - fit over the hub if youve used both you would know there is no further discussion
FollowupID: 735250
Follow Up By: Member Al (Sunshine Coast) - Tuesday, Aug 02, 2011 at 09:32
Getoutmore, are you telling me or Chris that a Hi-lift should not be used to change wheels? I have already said that twice.
I used the term "Hub Lifter" loosely as I could not remember the real name of the accessory I had in mind. It is in fact called a "Lift Mate" by ARB and heres a picture for the children that have not seen or used one...... Getoutmore?
And yes, I have used a hub lifter..... belonged to a mate!
Image Could Not Be Found
Whilst these are intended to hook into the wheel rim they can also serve to lift under a bumper or bullbar where there is no viable jack-point.
FollowupID: 735263
Follow Up By: get outmore - Tuesday, Aug 02, 2011 at 10:50
the ones I have and use slip over the hub and lift the hub directly up
used them for hangups and bogs never tyre changing
I do have jacking points on my bumpers and just thought I would try them to see what happens
what happens is even a standard hight 80 (a 105 would be simular)
for starters your starting off much higher on the jack just to reach the bumper. Then by the time youve taken off all the upwards travel of the suspension which is at least 30cm your working on the top 25% of the jack and the wheel isnt actually lifted yet so b the time the wheel is lifted things are pretty unstable for the intention of changing a wheel. definitly not recomended
FollowupID: 735268
Reply By: TravelToy - Tuesday, Aug 02, 2011 at 00:02
Thanks for the replies so far !
I forgot to mention that I'm looking for a solution to change tires in an offroad situation.
The hublifter is great, but as stated not suitable for changing tires I guess.
Kind regards,
Chris
AnswerID: 461565
Follow Up By: Member Al (Sunshine Coast) - Tuesday, Aug 02, 2011 at 00:15
Well you can get the wheel off alright that way with the strap/hooks on the wheel (although there is a hell of a thump) but getting the wheel back onto the hub is really hard! LOL Only joking!
But seriously, you lose about 150 to 200mm of lift with the hook/strap under the bumper.
In any case, it is dangerous to be removing a wheel with the vehicle supported by a high-lift jack from any lifting point. They are simply not stable enough.
What is wrong with a bottle or hydraulic jack under the axle?
FollowupID: 735246
Follow Up By: TravelToy - Tuesday, Aug 02, 2011 at 00:27
Well I guess there is nothing wrong with a bottle or hydraulic jack under the axle in most situations.
But when driving through deep mud it sometimes is impossible to get under the front axle.
Kind regards,
Chris
FollowupID: 735247
Follow Up By: Member Al (Sunshine Coast) - Tuesday, Aug 02, 2011 at 00:56
OK Chris, have you considered an Exhaust-bag Jack?
FollowupID: 735248
Follow Up By: get outmore - Tuesday, Aug 02, 2011 at 02:29
as mentioned the factory jack with a bottom plate will do fine if you need a high lift jack to change a tyre it will end in tears anyway
FollowupID: 735251
Reply By: ob - Tuesday, Aug 02, 2011 at 12:28
I use a Hi-Lift jack with an adaptor to fit over the hubs (loosen the wheel nuts first)
Lift the wheel just clear of the ground
Slip an adjustable stand under the axle and lower the vehicle onto it.
Slide the jack and adaptor off the hub and change the wheel.
Put the adaptor and Hi-Lift back on and lift the vehicle off the stand and remove said stand.
Lower vehicle down onto the new wheel.
Job done and no climbing under the vehicle or changing wheels on a jack.
It sounds complicated when written out step by step but not hard in practice.
ob
AnswerID: 461592
