Pop Top Caravan Roof
Submitted: Tuesday, Aug 02, 2011 at 08:17
ThreadID: 87932 Views:3537 Replies:4 FollowUps:0
Could any one tell me were and if a device is available to make it easier to lift my poptop roof?
We have a Golf poptop and had the roof replaced last year, since then have only used it once as the roof is too heavy to lift. I went back to the guy who fitted the roof but got the run around.
If any of you have any idea, I would greatly appreciate it.
Steve
Reply By: Member - Peter E1 (VIC) - Tuesday, Aug 02, 2011 at 08:36
Just buy any caravan magazine and you will see adds for the solution to your problem. That is if it is just a normal weight issue and not a mechanical problem. It could be also be one or more faulty gas struts. Worth a second opinion.
AnswerID: 461575
Reply By: ozjohn0 - Tuesday, Aug 02, 2011 at 10:59
Steve,
It maybe as simple as having the struts re-gassed or fitting stronger ones if the weight of the repaired roof was increased.
If that's not the problem then maybe Air Lifters would improve your situation.
www.rvairlifters.com.au
Cheers, ozjohn
AnswerID: 461579
Reply By: Batt's - Tuesday, Aug 02, 2011 at 19:48
A bit of WD40 fixed our old vans problem just sprayed it on the runners
AnswerID: 461637
Reply By: Timbo2 - Wednesday, Aug 03, 2011 at 00:44
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule .
Forum Moderation Team
AnswerID: 461662
