Mercedes ML270
Submitted: Thursday, Nov 27, 2003 at 21:44
ThreadID: 8803 Views:4583 Replies:6 FollowUps:3
My ML270 has a lag when you take off and I mean 2-3 seconds before it does
anything it can get quite dangerous at roundabouts the dealer said its normal
has anybody had the same problem
Reply By: Brian- Thursday, Nov 27, 2003 at 22:35
Hi Rogert,
If the dealer believes there is nothing wrong with your vehicle, then there is good reason to believe that Bi-tron will overcome the problem. I've heard some testimonies from Bi-tron users over the years get relief from this same problem you are experiencing.
You will need to e-mail me as I don't want to talk about Bi-tron on this forum. I do run an advertisment with the Exploroz.
My e-mail is:- brian@brianrogers.net
I'll wait your e-mail.
Regards,
Brian.
Brian Rogers. 525
AnswerID: 38743
Follow Up By: rogert - Sunday, Nov 30, 2003 at 21:06
Hi Eric
We have had the car from new and have had problems with sticky
accelerator 4 vists to dealer to fix, it used 5 lts oil in 15000 ks,gearbox locking up (New computor) gearbox pumping oil out of breather when towing less then two tons (Oil cooler fitted), dashboard lights not working
we had a pajero before this car and should have bought another one.
FollowupID: 82822
Reply By: pathfinder - Friday, Nov 28, 2003 at 08:46
Bi-tron! the cure for all! Have already seen it mentioned by Brian in about 20 posts...apparently it can cure the common cold as well and is better than viagra in the bedroom...
AnswerID: 38760
Follow Up By: Member - Bradley- Friday, Nov 28, 2003 at 15:35
Yeah he mentioned it is just 30 w base oil without any additives , cost from refinery about 80 cents per litre. BUT i've got a strange rash that it might fix LOL 8-)Moo... everyone knows what a Jackaroo looks like :-)
FollowupID: 82675
Reply By: stillthinkinaboutit - Friday, Nov 28, 2003 at 15:06
Hi Rogert,
Have a look at post 4332 in the archives or do a search on ML270, you will find others have the same problem.
Regards, Mark
AnswerID: 38805
Reply By: Brian from Bi-Tron Fuel & Oil Metal Treatment - Friday, Nov 28, 2003 at 18:46
Hi Rogert,
I do not say that Bi-tron will cure all mechanical problems that could be associated with a possible lubrication failure. I have had personal customers, I've heard and seen testimonials that give me a positive feel for the Bi-tron treatments. I've had plenty of sceptics who have given Bi-tron a go and now those people are my best distributors.
Being 30 SAE wt. gives more reason to believe there is NO additive in the Bi-tron.
You have nothing to loose and everything to gain. The Bi-tron CANNOT create a problem; it is only base oil without additives.
You should e-mail me for more information.
Regards,
Brian. Exploroz I.D. 525
E-mail:- brian@brianrogers.netBi-Tron Fuel & Oil Metal Treatment
AnswerID: 38833
Follow Up By: Old Jack - Sunday, Nov 30, 2003 at 23:04
the MB diesel engine uses high pressure electronic direct injection, the problem is with the engine managment system. what part of the vehical would you place the oil in?
FollowupID: 82833
Reply By: Eric Experience. - Friday, Nov 28, 2003 at 23:23
Rogert.
Being in a position to buy a ML270, I pressume you will not be taken in by snake oil salesmen. I am interested in this problem and wonder did you buy this vehicle second hand because there was a gent on this forum who had an almost identical post about 3 monts ago and he siad he was going to sell the M class because MB could not fix it. I considered buying it then decided the new did pajero was a better vehicle for my purposes, I went to MB to get a cct diagram of the throtel system and MB refused to let me even look at it. Not a very friendly company. Eric.
AnswerID: 38850
Reply By: Brian from Bi-Tron Fuel & Oil Metal Treatment - Monday, Dec 01, 2003 at 15:19
Hi Rogert,
Snake oil it ain't. I wonder if Eric ever changed from B&W TV to Colour or VCR to DVD it's called advancing with technology. There were treatment availabe in the 1930 that are still around today. The Bi-tron, through enginering and technology advancement have taken OIl & Metal treatments from 1995 through 2003 with 21st Centuary Technology. If anyone wants to know how the Bi-tron can give positive results, you should E-mail me at :- brian@brianrogers.net
Brian. Bi-Tron Fuel & Oil Metal Treatment
AnswerID: 39057
