memorymap 4wd australia rastermap collection 2010
Submitted: Sunday, Aug 07, 2011 at 14:24
Member - SKL
purchased above dvd with the intent of loading onto a ipad 2 wifi gps via windows 7 on an imac (partitioned hard drive with bootcamp assistant. Eventually got most of the maps to download,missing a few. Biggest prob is cant get it onto ipad using every bit of info i can find just does not want to play. For those out there with more savvy if it does work can all the content from the dvd be loaded to the ipad and just use it as a gps not needing to do anymore unless i want to down load additional maps with a sim installed. Apple store apps in itunes does not seem to work.
Thankks
Reply By: Member - Tony S (WA) - Sunday, Aug 07, 2011 at 19:41
May-be you haven't got enough memory. Memory Map needs to have it's own program to run MM maps. Also, you need Ozi CE if using Raster 250 tho maps.
Tony
462065
Follow Up By: Member - Boobook - Monday, Aug 08, 2011 at 09:20
Tony Ozi CE has nothing to do with the OP issue and the 250K will run on Memory map OR Oziexplorer.
735807
Follow Up By: Member - Tony S (WA) - Monday, Aug 08, 2011 at 10:35
Yes I agree with you I don't have a Ipod however, the 250 tho maps will not operate correctly on a gps hence Ozie CE. [ at least they don't on my two ]
Tony
735810
Reply By: mikehzz - Sunday, Aug 07, 2011 at 20:10
Adding the maps to the iPad is pretty simple using iTunes. You just scroll to the bottom of the apps tab, select Memory Map and add the files by browsing to where they are stored on your computer. Mike
462070
Reply By: Member - Boobook - Monday, Aug 08, 2011 at 09:23
Firstly, your Memory Map Hema collection will run on the windows 7. You SHOULd have a complete set of maps.
Have you licenced the CD. Go to the Memory map web site and licence it. You also need to buy the IPAD version. You will see this in the registration pages on the web site or you can purchase it in the apps store. It should all then run al the PC and the Ipad.
462090
