Boss Air Bags
Submitted: Thursday, Aug 11, 2011 at 17:45
ThreadID: 88415 Views:2804 Replies:5 FollowUps:3
Hey Bungarra I see your post dated Feb 2008 on Boss air bags, did you go for them? if so how have they performed? and where did you get them from?
Thanks in advance
Rod
Reply By: Member - Serendipity(WA) - Thursday, Aug 11, 2011 at 18:49
Hi Rod
I have also bought Boss air bags for my ute. They have been great and will often carry the max load with ease.
I ended up purchasing the entire boss kit which included Boss compressor PX 07, 15 litre air tank, water trap, left and right controllers with gauge, and the air bags. All for $990. I think they will be a bit more now though.
Had a problem with the compressor with the butterfly valve coming loose and ruining the piston and barrel. I have recently ordered a new piston and barrel for $80. That compressor smashes the air in. And it is 100% duty cycle so once I have done my tires I can pump up other tires and the compressor doesn't time out with overheating.
Serendipity
AnswerID: 462344
Reply By: Member - bungarra (WA) - Thursday, Aug 11, 2011 at 23:32
yes installed and definately a good choice.
have recently purchased the tank and the compressor as well as serendepity has posted but not installed as yet
VKS 1341
AnswerID: 462366
Reply By: Rod W - Friday, Aug 12, 2011 at 08:49
Thanks for that fella's.
Now what about the lifetime guarantee, did they have that? and where did you buy them from, was it here in WA?
Rod W
AnswerID: 462380
Reply By: Member - Phil G (SA) - Friday, Aug 12, 2011 at 10:33
Gday Rod,
I've got the Boss airbags too - good quality, and I've had them for about 4 years now. Just don't put too much pressure in them or you might bend the chassis (depending on your vehicle) - I treat them as a load levelling device, not a substitute for adequate springs. I never put more than 25psi in mine even though Boss say you can go to 100. They will reduce your vehicle's articulation - on mine there is about 80mm less travel.
AnswerID: 462402
Follow Up By: Rod W - Friday, Aug 12, 2011 at 14:51
Thanks Phil, yep I want to load level as well.
FollowupID: 736220
Reply By: olcoolone - Friday, Aug 12, 2011 at 12:54
G'day Rod, your not putting bags under the Hilux?
We have been looking at airbags (to my dislike) for our Landcruiser and it looks like we are going to use Firestone's due to the connector going into the air bag as opposed to Polyairs.
Whats the reason for going Boss?
AnswerID: 462412
Follow Up By: Rod W - Friday, Aug 12, 2011 at 14:59
G'day olcoolone,
I don't have a Hilux. I have a Troopy.
I was looking a Boss as Bungarra's original post mentioned "lifetime guarantee", but in looking on Boss's website their "lifetime guarantee means 3 years and pro-rata thereafter. I'll be out checking Firestone also.
FollowupID: 736223
Follow Up By: olcoolone - Friday, Aug 12, 2011 at 17:11
Wrong Rod W... there is another Rod W who is very active on 4wd forums and he runs a website for 4wd vehicle mods.
http://www.vehiclemods.net.au/contact-us/default-form
FollowupID: 736238
