The "Morning Glory" cloud formations..
Submitted: Saturday, Aug 13, 2011 at 09:07
ThreadID: 88444 Views:5277 Replies:4 FollowUps:4
Hi "All"..
The time of the year is fast approching for this and the weather has certainally changed in the last week, people around here are saying it is not far away now so here is hoping we will catch it this year .....
Below is a bit of info on it..
Cheers and enjoy... J&M&kids
The Morning Glory cloud is a rare meteorological phenomenon occasionally observed in different locations around the world. The southern part of Northern Australia's Gulf of Carpentaria is the only known location where it can be predicted and observed on a more or less regular basis. The settlement of Burketown attracts glider pilots intent on riding this phenomenon.
Image Could Not Be Found
Description
Morning Glory clouds can most often be observed in Burketown in September to mid—November, when the chance to see it early in the morning is approximately 40%.
A Morning Glory cloud is a roll cloud that can be up to 1,000 kilometres long, 1 to 2 kilometres high, often only 100 to 200 metres above the ground and can move at speeds up to 60 kilometres per hour. Sometimes there is only one cloud, sometimes there are up to eight consecutive roll clouds.
The Morning Glory is often accompanied by sudden wind squalls, intense low-level wind shear, a rapid increase in the vertical displacement of air parcels, and a sharp pressure jump at the surface. In the front of the cloud, there is strong vertical motion that transports air up through the cloud and creates the rolling appearance, while the air in the middle and rear of the cloud becomes turbulent and sinks.
The cloud can also be described as a solitary wave or a soliton, which is a wave that has a single crest and moves without changing speed or shape.
History of exploration
Unusual cloud formations have been noticed here since ancient times. The local Garrawa Aboriginal people called it kangólgi. Royal Australian Air Force pilots first reported this phenomenon in 1942.
The Morning Glory cloud of the Gulf of Carpentaria has been studied by multiple teams of scientists since the early 1970s. The first studies were published by Reg H.Clarke (University of Melbourne). Multiple studies have followed since then, proposing diverse mathematical models explaining the complex movements of air masses in region.
Causes
Despite being studied extensively, the Morning Glory cloud is not clearly understood.
Regardless of the complexity behind the nature of this atmospheric phenomenon, some conclusions have been made about its causes. Through research, one of the main causes of most Morning Glory occurrences is due to the mesoscale circulations associated with sea breezes that develop over the peninsula and the gulf. On the large scale, Morning Glories are usually associated with frontal systems crossing central Australia and high pressure in northern Australia. Locals have noted that the Morning Glory is likely to occur when the humidity in the area is high, which provides moisture for the cloud to form, and when strong sea breezes have blown the preceding day.
Scenario for formation
The following is a summary of the conditions that cause the Morning Glory cloud to form in the Gulf of Carpentaria (after hypothesis of R.H.Clarke, as described in 1981)[1]. First, Cape York which is the peninsula that lies to the east of the gulf is large enough that sea breezes develop on both sides. The breeze from the Coral Sea coast blows in from the east and the breeze from the gulf blows in from the west. The two breezes meet in the middle of the peninsula, forcing the air to rise there and form a line of clouds over the spine of the peninsula. When night comes, the air cools and descends and at the same time a surface inversion forms over the gulf (where air temperature increases with height). The densities in this stable layer are different above and below the inversion. The air descending from the peninsula to the east goes underneath the inversion layer and this generates a series of waves or rolling cylinders which travel across the gulf. These cylinders of air roll along the underside of the inversion layer, so that the air rises at the front of the wave and sinks at the rear. In the early morning, the air is saturated enough so that the rising air in the front produces a cloud, which forms the leading edge of the cylinder, and evaporates in the back, hence forming the Morning Glory cloud. The cloud lasts until the surface inversion disappears with the heating of the day.
This is one scenario that explains the formation of the Morning Glory Cloud over the Gulf of Carpentaria, but other explanations have also been proposed.
There are other ways in which Morning Glory clouds form, especially in rarer cases in other parts of the world, but these are far less understood.
Local weather lore in the area suggests that when the fridges frost over and the café tables' corners curl upwards at the Burketown Pub, there is enough moisture in the air for the clouds to form. Reportedly, all winds cease at ground level as the cloud passes over.
One vantage point to see Australia's Morning Glory is from Burketown in the remote Far North Queensland around September and October. Towns in this part of the world are small and a long way apart, and Burketown has an influx of glider and hang-glider pilots at this time of year.
Other reported occurrences
Although the Morning Glory clouds over the southern part of Carpentaria Gulf are the most frequent and only here they can be predicted at a certain time of year, similar phenomena occasionally have been observed in other areas of the world, e.g. over the Central United States, the English Channel, over Berlin, Germany, Eastern Russia, as well as other maritime regions of Australia.
Morning Glory type roll clouds have been reported to occasionally happen off the Mexican coast in the Sea of Cortez. The phenomenon has also been observed from Sable Island, a small Canadian island located 180 km southeast of Nova Scotia; a Morning Glory cloud also passed through Yarmouth, Nova Scotia in April 2009[3]. In contrast to Australia’s Gulf of Carpentaria where the Morning Glory cloud is visible in the morning, the clouds experienced in Nova Scotia have all occurred during the evening. Rare examples have been observed via satellite observation over the Joseph Bonaparte Gulf in the Eastern Kimberley region of Australia as well as over the Arabian Sea. A Morning Glory cloud was observed in 2007 over the Campos dos Goytacazes bay in the state of Rio de Janeiro, Brazil
Reply By: Member - Fred B (NT) - Saturday, Aug 13, 2011 at 09:51
Hi Jo and Mel,
what a great post. It has to rank right up there with some of Doug's sunday history threads.
Well done guys. A really great read.
regards
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 462484
Follow Up By: Skippype - Saturday, Aug 13, 2011 at 16:14
I agree. Great post.
Skip
FollowupID: 736302
Follow Up By: Member - Joe n Mel n kids (FNQ - Saturday, Aug 13, 2011 at 17:17
i would have to say Doug's "Sunday" history's are very good and i for one confess to taking a laptop on holidays, getting it out on Sundays and looking for the history post, he does a really good job eh... and then it is "Landline" on telly and the day begins hahah
Cheers and thanks..
Joe
FollowupID: 736307
Follow Up By: Big Woody - Saturday, Aug 13, 2011 at 20:27
It is up there with one of Dougs threads because he has already posted this last year.
Doug's Thread
And Wikipedia did the rest - here
FollowupID: 736315
Follow Up By: Member - Joe n Mel n kids (FNQ - Sunday, Aug 14, 2011 at 11:46
Hi "Big Woody" as i said Dougs are VERY good .... i dont for a second have any desire to compair what Doug does to that above, now seeing the post by Doug i remember it as we made many trips over to Burktown last year after reading it but never got to see it, hence my interest this year to not miss it again and YES it is a direct "copy n paste", i have no problems with that, if you do and dont want to know about something that i concider to be a wonder only found here then DONT READ IT !!!
Oh and below is COPY n PASTE ... (i dont own a sattelite, sorry about that !!)
Image Could Not Be FoundImage Could Not Be Found Image Could Not Be Found Image Could Not Be Found Image Could Not Be Found Image Could Not Be Found Image Could Not Be Found Image Could Not Be Found
Most "information" on this site would be just that, if we all sat back on our fat asses and took the micky out of others that at least BOTHER to contribute even if it is a copy n paste then it would be a forum of complainers complaining about complainers complaints ...... it is starting to drift to that anyway lol
That said i will now post some MORE copys n pastes of information about the area i live in as it is very interesting to ME and hopefully to others, it is very remote and lots of NON COMPLAINERS would wish to know more about it and come and see it .... i love it up here, i dont know anything about it up here and i LIVE here so i will COPY n PASTE and hope to hell someone else likes it, if not the mods will very quickly scrub me hahaha
Joe, Melissa, 3 kids, 1 dog, 1 puppy, 1 cat all living at 1 Roadhouse in Doomadgee FNQ .............
FollowupID: 736359
Reply By: Fiona & Paul - Saturday, Aug 13, 2011 at 12:51
That's another reason we have to call in on you guys when next we are up that way Joe, a few of those shots is what I need in my portfolio.
Great information and another reason to take the bride north again at this time next year. I've seen bits and pieces about this from time to time but never thought much about it - different now.
Many thanks Joe.
Paul H
Paul H
OZ Downunder
AnswerID: 462495
Reply By: BrownyGU - Saturday, Aug 13, 2011 at 15:06
Thanks J,M & K,
A good read, we will be there abouts in a couple few weeks, hopefully we will be lucky enough to get a glimps, it certainly is spectacular from the air!
Cheers....Browny
AnswerID: 462499
Reply By: ao767brad - Sunday, Aug 14, 2011 at 09:00
If you have a chat to the local pilot see if he/she will take you up as I still remember flying it like it was yesterday (20 years ago). One of the worlds best natural phenomena, you will never forget flying along the roll cloud with the engine at idle and still doing 100-150kts (180-280km/hr) as you fly the wave.
AnswerID: 462546
