Uluru to Brisbane
Submitted: Sunday, Aug 14, 2011 at 19:52
Dean L
Hi ,I have tried to look at my limited maps that I have,without sucess,to see if there is a reasonably direct route from Uluru to
Brisbane.Can someone plese tell me the best way and the condition of the road,I am thinking of doing the trip from
Perth to
Brisbane via the middle.
thanks
Dean
Reply By: p_marns - Sunday, Aug 14, 2011 at 21:48
Hi dean, I am going from
brisbane to uluru in a few weeks and i am heading straight west to
birdsville then north to
boulia then west again to alice via the plenty hwy. not sure if its the quickest but its reasonably direct.
462618
Follow Up By: Bob Y. - Qld - Sunday, Aug 14, 2011 at 22:12
To go via
Windorah, then up to
Bedourie would be shorter again, and probably the most direct route, using the better roads.
If you like bitumen, then go via
Longreach,
Winton and
Boulia. But that's quite a bit further.
Bob.
736419
Reply By: Member Al (Sunshine Coast) - Sunday, Aug 14, 2011 at 22:21
Dean, Your problem is that you have both the
Simpson Desert and Lake Eyre in your path.
Other than going across the
Simpson Desert track via
Birdsville, the Plenty/Donohue Highway starting from just north of
Alice Springs and via
Boulia is the most direct route. The road is unsealed but formed and with loose stones but OK for a 4WD driven to conditions. It would be rather rough on a 2WD
sedan.
Otherwise you would need to go South to
Lyndhurst and then up to
Innamincka before heading West to
Brisbane. Again, some unsealed roads but of good condition.
To stay on sealed bitumen roads you would need to go South to
Port Augusta then head through
Broken Hill and
Cobar to
Brisbane. A long route.
462622
Reply By: Dean L - Sunday, Aug 14, 2011 at 22:42
Thanks for the reply's,I have a 4.2 turbo patrol ,so I don't mind some off road stuff.I will try and track down a good map to work out the distance
Dean
462624
Reply By: wizzer73 - Monday, Aug 15, 2011 at 20:49
outback hwy
What about the outback hwy? Or is this too far north of brissy
wizzer
462690
