Spinnfex Theory
Submitted: Thursday, Aug 18, 2011 at 15:20
ThreadID: 88531 Views:2772 Replies:1 FollowUps:3
Recently we bumbled along the Madigan line for days on end and collected a lot of Spinnfex along the way.
This line (its not really a track) has much more grass on it than Canning etc.
Traditionally petrol cars like my 4800 Patrol have been considered more of a issue of catching fire from such grass getting caught in the hot exhaust particularly around the Catalytic converter.
When I started out on this trip I was quite concerned and cleaned under the car at every stop, i.e. over 25 times usually 4 times per day.
We made sure we were prepared for fire.
By the end of the trip I was much less concerned, I collected less Spinnfex
and had developed a bit of a theory which helped reduce it.
We rotated leaders through 5 cars on the drive and as soon as it was my turn in front I noticed a difference in grass collection despite the fact that the cars were always in the grass.
I made 2 observations from this experience.
1/ The cars speed were very slow typically 10-15kmh.
2/ The car picked up less grass while leading.
It seemed to me that the slow speed meant that when a car went over the grass it tended to bend it not smash it and this meant less loose grass.
By the time several cars had run over it there was significantly more loose grass that could potentially be picked up.
I then got to repeat the experiment with the same results , very roughly I guessed that twice as much grass got picked up by the last car.
Am wondering if others may confirm this observation.
Many times I had Spinnfex grass caught in around the Cat converter but the low speed with the engine mostly just above idle really meant less heat and less potential danger.
It actually seemed that the 4 other cars (diesels) all got at least as hot.
No, this is not some twisted logic so I can be leader all the time !
Image Could Not Be Found
Reply By: Member - MUZBRY(Vic) - Thursday, Aug 18, 2011 at 16:12
Gday Robin
Just looking at the pictures and notice the "rose joints" on the sway bar. Are they better and how do they last?
Just another question. why the old vehicle and not the new ?
AnswerID: 462874
Follow Up By: Member - Keith P (NSW) - Thursday, Aug 18, 2011 at 16:34
I reckon ...just for that trip...I would be taking that cover off the cat .
Cheers Keith
FollowupID: 736672
Follow Up By: Robin Miller - Thursday, Aug 18, 2011 at 16:44
Hi Muz
I just decided to do up the suspension as good as I could and the rose joints link are stronger - but this was the first trip , and while it worked really well I can't comment on Longevity.
Taking the older manual 4800 over the newer auto 4800 Gu was a trickeyer descision.
A factor in getting the new car last sept was to have it ready for the Madigan.
I did all the good stuff to the new car but became concerned the the auto wasn't as good for this application. In an earlier matched test the manual gave significantly (22%) better consumption in the heavy stuff.
Also the ability to rock the manual car out from between 2 moguls proved to be handy (as per current post "26 Hours" - photo ).
The better control of the manual , while not a big thing , sort of tip the advantage to it.
But I'm off to baby sit someones luxury complex at Torquay for a few days and the new car looks a lot prettier, and will have no trouble if I can find someone to rescue from a carpark.
FollowupID: 736673
Follow Up By: Member - MUZBRY(Vic) - Thursday, Aug 18, 2011 at 17:10
Robin
If you need a tow,, just call.
FollowupID: 736679
