Discover Aus with ETREX
Submitted: Sunday, Nov 30, 2003 at 10:18
Cruisin
Hi all new user here.
I have a Laptop running OziExplorer Software connecting to a Etrex GPS via a serial cable. The GPS interface is set to NMEA out and this works fine via Com1 of my Laptop. When I try and use the Magellan DiscoverAUS mapping software with the Etrex set to the same settings. DiscoverAus does not detect the GPS.
I may be wrong but I was under the opinion that NMEA was a standard protocol that should work between differing vendors. Is this true.
Could anyone tell me if a Garmin ETREX will work with the Magellan DiscoverAUS software. Any help greatly appreciated.
Cheers Peter
Reply By: Member - Ray - Sunday, Nov 30, 2003 at 11:54
Discoveraus will only work with Magellan receivers. I have it running on a magellan M eridian via a laptop and a remote monitor on the dash and it is great. But it has a severe lag problem if it is run only on the GPSR.
38950
Follow Up By: theratt - Sunday, Nov 30, 2003 at 16:06
not sure about that ray i have a furuno GPS removed from my boat and fitted to my vehicle and it all works fine with discoveraus and GDtracks
82807
Follow Up By: petprass - Monday, Dec 01, 2003 at 11:25
Ray - the lag problem can be overcome by ensuring that the regions that you draw and load up are around 15mb in size rather than the maximum allowed of 16mb.
82853
Follow Up By: theratt - Monday, Dec 01, 2003 at 11:39
Ray what type of remote monitor are you using i would like to have
a small screen on the dash somewhere ??
82854
Reply By: Cobra - Sunday, Nov 30, 2003 at 23:58
I have been told that Magellan stuff will not work with Garmin
39004
