Another battery question!
Submitted: Friday, Aug 19, 2011 at 15:54
ThreadID: 88565 Views:2724 Replies:8 FollowUps:7
I purchased a second hand 135 amp/h battery from ebay. All good on the way up to Cape York, seemed to charge without issue and sit at around 12.8 volts. On the way back however it stopped charging altogether. I had 14 volts coming through the Anderson plug on the car but it was not charging the battery. Back at home I have placed it on a charger but within 2-3 hours of removing the charger it sits at a very sad 9 volts. My question- is it dead and am I left with a very heavy paperweight?
Reply By: Evakool - Friday, Aug 19, 2011 at 16:05
Just to get a bit more information;
What type and brand of battery?
Do you know the age of the battery?
What type of battery charger?
After you unplug the charger how quickly did you check and see 9 volts?
Did you put a load on the battery after you un-plugged the battery charger?
AnswerID: 462979
Follow Up By: Vic Heals - Friday, Aug 19, 2011 at 16:48
Eaton powerware VRLA battery
No idea of the age
Basic Arlec style battery charger
After I unplug the charger it reads 12 .7 volts, then gradually over a space of about 3 - 4 hours it drops down to 9 volts. Its been off charge for 36 hours now and is down to 8.8 volts.
I have not put anything on the battery as I fear I know the answer to my question already.
FollowupID: 736788
Follow Up By: Puma1 - Friday, Aug 19, 2011 at 19:12
The fear of the moment of truth!
The moths are getting edgy in anticipation of the wallet unfolding:-)
FollowupID: 736821
Follow Up By: TerraFirma - Friday, Aug 19, 2011 at 21:12
My detective work tells me that most of the Eaton Powerware Batteries are used in UPS (Uninterruptible_power_supply) applications in maintaining emergency power to computer, hospital or critical equipment, these are often sold off via Ebay and other channels, I would suspect your battery was already nearing end of life and your trip finished her off. Lesson learnt, nothing is a bargain unless it carrys out it's objective over a minimal period. Buy a Fullriver DC AGM Battery and Ctek or other good quality charger and enjoy years of hassle free operation. (Hindsight LOL..!)
FollowupID: 736834
Follow Up By: Vic Heals - Friday, Aug 19, 2011 at 21:40
Thanks for that. I guessed as much. It was a bargain and did make it all the way to the tip and half way back so I can't complain. Lesson learnt!
FollowupID: 736838
Reply By: TerraFirma - Friday, Aug 19, 2011 at 16:06
What was the brand and type of battery? AGM, Lead Acid etc. Sounds like it has died, if you had a smart charger like a Ctek you could try doing a recondition etc..? What type of charger do you have?
AnswerID: 462980
Follow Up By: Vic Heals - Friday, Aug 19, 2011 at 16:55
I did wonder if a Ctek would be able to fix it but was closer to cutting my losses and thinking about the old saying "When something seems to be to good it probably is....."
At my age I should also remember "a fool and his money....."
FollowupID: 736791
Follow Up By: Puma1 - Friday, Aug 19, 2011 at 22:30
Another usefull one
Once bitten twice shy!
FollowupID: 736847
Reply By: Puma1 - Friday, Aug 19, 2011 at 16:27
Buy a dingy you've already got an anchor!
I'm guessing but it sounds like a collapsed cell, probably all that bouncing around going up to the pointy bit!
Look on the bright side - at least you were happy with the bargain during the trip.
Doh!
AnswerID: 462982
Follow Up By: Vic Heals - Friday, Aug 19, 2011 at 16:50
ha ha - I think it would be too heavy to even use as an anchor.
FollowupID: 736790
Reply By: Tonyfish#58 - Friday, Aug 19, 2011 at 16:55
Lot of work but might be good for sinkers then :-)
Cheers Tony
AnswerID: 462985
Reply By: Member - Scott A (NSW) - Friday, Aug 19, 2011 at 19:27
Out of curiosity, how much did the ebay bargain cost you?
AnswerID: 463004
Reply By: Dennis Ellery - Friday, Aug 19, 2011 at 20:53
Why would anybody buy a second-hand battery?
There is no way of knowing its previous history, maintenance, remaining life or capacity.
Cut your losses - chuck it in the bin.
AnswerID: 463018
Reply By: Vic Heals - Friday, Aug 19, 2011 at 21:41
Thanks everyone for your input. For the price I paid and the use I got out of it it wasn't too bad.
Anyone need a doorstop?
AnswerID: 463022
Reply By: River Swaggie - Sunday, Aug 21, 2011 at 06:03
When it comes to Batteries thats one area i wouldnt buy secondhand fullstop.
AnswerID: 463119
