Lighter Caravans
Submitted: Friday, Aug 19, 2011 at 21:29
ThreadID: 88571 Views:5757 Replies:6 FollowUps:3
I am looking for a lighter caravan ( not pop top) with a shower/toilet or en suite.
Need to be under 2000kg loaded for my Nissan x Trail .
I do want to keep the current vehicle as it is so good on fuel ( diesel) with 6 ltr per hundred unloaded and 10 ltrs per hundred with our current van on 1164kg.
Like the look and price of the Diamond Gem.
John B
Reply By: Geepeem - Saturday, Aug 20, 2011 at 08:57
HI John,
I do not know anything about the Diamond Gem but my suggestion is to also have a look at the Gemhunter Custom Caravan range of light weight vans. My BIL is looking for a light weight van as he has also a low towing capacity with his 4X4. He is a retired tradie and was very impressed with Gemhunter and their construction method of fibrelass/foam sandwich panels. They are a Queensland company if you are in this area to inspect first hand.
I have no association with company - just giving you another one to look at perhaps.
AnswerID: 463043
Reply By: ao767brad - Saturday, Aug 20, 2011 at 10:35
Adria and Giest have been around australia a while now and seem to have a reasonable following.
AnswerID: 463056
Follow Up By: ozjohn0 - Sunday, Aug 21, 2011 at 14:15
Giest went bust in Australia couple of years ago.
Ozjohn.
FollowupID: 736986
Reply By: Member - peter C (VIC) - Saturday, Aug 20, 2011 at 15:55
have alook at the karakampa van made in victoria. all fibreglass body and fit out with full ensuite and weight of approx 1350kg. made by a guy who used to make boats and his experience shows
AnswerID: 463071
Reply By: Nomadic Navara - Saturday, Aug 20, 2011 at 23:06
Site Link
AnswerID: 463111
Reply By: paulnsw - Sunday, Aug 21, 2011 at 07:06
Jurgens Sungazer is hard to beat. Jurgens has none of the issues of imported caravans like Adria or the sway problems of Adria.
AnswerID: 463125
Reply By: John B - Sunday, Aug 21, 2011 at 13:55
Thanks for replys
Would like a standard aluminium clad Aussie Van.
Looked at Millard 1450kg
Windsor 1595kg
Olympic Javelin 1620kg
Royal Flair 1700Kg
Diamond Gem 1450kg
Bit suspicious of the 1450 kg vans are they weighted without Air Conds etc.
AnswerID: 463165
Follow Up By: ozjohn0 - Sunday, Aug 21, 2011 at 14:13
I'm guessing the weights are TARE weights which is for an empty van and empty water tanks and LPG cylinders.
If the Diamong Gem is supplied with an Air Con then the manufacturer must amend the Vin Plate to include the air con in the Tare. The same applies if the A/C is fitted by the dealer.
It's the loaded weight that will have the most bearing on what you can tow.
Of those you've listed the Royal Flair runs rings around the rest. But I will admitt to not knowing the Diamond product and wonder who builds them.
Ozjohn.
FollowupID: 736985
Follow Up By: John B - Monday, Aug 22, 2011 at 08:36
All wewights are TARE I agree Royal Flair the Best Choice but 1700kg compared to 1450kg thats a250kg diffference
FollowupID: 737050
